Maybe the s15 costs less because its got a smaller engine, its a smaller car and doesnt come out in a 4-door model?
The s15 responds far better to modification than an r34. S15 is a sports car, the r34 25gt or gt-t drives like a family car in comparison.
Get the Silvia :)
Once you have driven all these cars and know more about them.. you'll realise theres two options.. either a silvia or a gtr. Dont bother messing around with gts-t's unless you have kids :)
I had no problems with my S15 during the 2 years I had it. The only issue I had with it was the fact that the dash scratches very easily.
Yes go onto the www.silviansw.com and ask the S15 owners what they think.
I can't agree that going from a 1993 R33 skyline to a S15 Spec R is downgrading. It's not like atticus is comparing between a 2001 R34 GTT and 2001 S15 Spec R. He's current ride is
a 93 model R33. Even though The skyline may be higher in the hierarchy, there is a huge build date and market value difference between both the cars.
Ask yourself if going from a Honda prelude 1993 model to a 2001 integra is a downgrade. Which is higher in the hierarchy?
I like either car, but they are different cars for different purposes.
Have a look at what you'd like the car to do, and see which suits better :D I personally like the skyline, but thats a combination of looks, size, taste and use.
I'd sure have an S15 NEXT to my line :D
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
