what do you mean by load? a turbo should generate boost if it has enough exhaust gases passing through the turbine. If you rev the shit out of it while its sitting then boost should be made. A mates WRX makes enough boost while sitting (only average revving) to make quite a loud BOV sound.
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1283562
yep spooling/boosting. i tried to bypass the stock boost controller (maybe with autos the ecu opens the wastegate right up) with a turbosmart T-controller but with no luck. I installed it correctly(i think) but i wouldn't make any boost over 1 or 2 psi. When installing a manual boost controller what needs to be modified from the r34 stock hoses? apparently the stock setup has a tube coming from the vacume and the intake, shouldn't it just be vacume?
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1283749
It is impossible for the ECU to open the wastegate before the Actuator allows it, so there is no way for this to happen. You need to get your turbine wheel spinning fast enough for the compressor to creat positive manifold pressure. If you build your revs up to about 3000rpm then kick it, the turbine will already be spinning and you will create 'some' boost.. You essentially need to get the turbine spinning with some hot loaded exhaust gases.. I too cna create enough boost to get the BOV's to make some noise, but this is dependant on too many other factors to comment on..
I suggest that you do some research into the operation of Turbochargers before expecting anything out of them. A very very good book for this is Maximum Boost by Corky Bell, has enough of the basics so that the beginners can learn and enough of the good stuff so that the more seasoned of us can gain knowledge and fill in the gaps. If you don't want to buy it, download it...
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1283984
yeah i would like to know alot more about turbo setups but im a bit of cheap skate so i'll need to find some "free" online info. Another problem i came across was when i removed the Turbosmart manual boost controller and connected the stock soilinoid back up; the stock boost goes up just below the halfway mark (on the factory boost gauge), now only does half that. How the hell did i lose half of my precious boost?
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1285052
yeah i think when ur free reving u wont get full boost...the only way to get full boost is under load as someone else has stated, or so i understand.
as for the missing boost...did you plug the solenoid back in? if you didnt ur car would only be runnin 5psi which is half of half..LOL. double check the pipework again.
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1285289
Free reving will give you boost, but this depends on:
Turbo size & the engines compression ratio.
If you have a huge turbo say GT3040 it won't make anyboost at all while free reving, only when under full load.
But if you have a stock turbo with lower compression its not going to make as much boost when free reving, otherwise stock compression you can get the turbo to spool a fair bit when free reving the engine.
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1285371
I have sr20 with small trust turbo and it doesn't make any pressure on the boost gauge free revving.
If I had a BOV however it would be enough to vent it if the spring wasn't tight.
I don't know what causes this but you don't want boost when free-revving or you'd kill your engine :D
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1285433
My stock RB20 will go from ~20psi vacuum to 0psi in neutral so there IS a difference being made, but as mentioned there's not enough exhaust gases (to drive the turbine) being generated when free revving to produce "boost", they aren't directly related to RPM but load.
Try www.howstuffworks.com for basic turbo info. and to gain an understanding of basics physics (relationships between power, energy, etc.) .
Edit: For comparison a Supercharger WILL make boost when free revving, because it's hooked up to the crank and therefore affected by engine revs, it is consuming engine power (typically 10-20kw) to produce that pressure. But it WONT raise the pressure with load, which is why Turbo's are typically more efficient, giving you more power when you need it (when under greater load). HSW has plenty of info. on them too.
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1285707
My biggest problem at the moment is to get my stock boost back, would the ecu need a reset after connecting the stock soilinoid back up?
If a BOV can go off when revving in idle then has to be positive pressure, therefore some was made. On that subject, has anyone here installed a Mach 1 GFB BOV on an R34? whats up with the stock "mitsubishi" plumback.
https://www.sau.com.au/forums/topic/69341-no-boost/#findComment-1287425
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
