This is a bit of a weird request, but anyway here goes.
My friend is finishing up her phycology degree and needs someone to interview for one of her assignments. She's having trouble finding someone that fits the profile - I figured with lots of young guys here there may be someone that fits and is willing to spare an hour or two to meet with her. What do you get out of it? nothing :D But she is a very nice girl - and hot :(
Anyways here is what she sent me:
The research project is for a Social Psychology subject. The background for the project is that more and more people are being hired as casual workers rather than permanent workers. This high percentage are people aged between 18 and 26. The project examines what it's like to be a casual worker. You will be asked about topics such as how you feel about being a casual, about the work you do and preferences regarding work arrangements.
She is looking for someone who is aged between 18 and 26 and is working casual hours in their field of study. Someone who has actually completed their degree or close to completion.
Any industry but must be working irregular casual hours.
If anyone is interested in helping out this lovley young lady - then PM me or reply in here and i'll get you in contact with her.
Thanks
Hey, not sure if i fit the bill exactly but here i go:
Age 22
At uni doing mech eng, 1 year to go of of 6 year degree.
Have been working casually as a student mech. engineer for the last 2.5 years.
Usually work 1 day per week, but sometimes anywhere between 1 and 5 days per week.
Also work another casual job at the same time, not in eng. field.
Im in SE suburbs, send me a pm if she's interested.
Rhett
My friend asked me to post this:
Thanks to all you guys for offering to help with the "casual positions" but I'm afraid it was a case of first in best dressed. Also, I don't know about the rest of you guys but Rhett definately was the right man for the job - and what a great job he did too.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
