we're talking about a guy trying to do up his GTR and using EBC and SAFC when he should do it properly and buy a FC and remove the restrictor. Then as funds permit buy a EBC if needs be. I have removed my restrictor had PFC tuned properly and never had a problem. Put an accurate guage on the boost level and showed 1.02Bar from 4500rpm - 7200rpm. Thats pretty good in my books and even better the restrictor removal cost me nothing.
  • Replies 57
gtr98,
nobodys disagreeing with you,but if were talking about wasting money,u spent money on a power fc u didnt need if ur only running 1 bar.
If i ever want to do more mods one day then i dont have to sell my SAFC and buy a PFC. I havent butchered my wiring and if i ever want to return the car to standard then i can do it in about 5 mins and im sure i can sell a PFC a lot easier than a SAFC.
Im not going to get into a slagging match with you mate, so i will leave it there. Each to their own. You own a GTR built well, reliable, and great fun to drive. Dont turn it into a piece of crap like so many out there. Do it properly once and never have a problem again.
Cheers
Cheers
dood wasnt trying to have a slanging match with you,i have 2 gtrs both with power fc,the point i was making was u dont need a pfc or an afc if ur only running 1 bar,standard ecu is more than capable of 1 bar,theres a number of gtrs running around with 1 bar making 240kw plus at the wheels running standard ecu
And with our crapy fuels one day those motors will go POP.
rubbish.
if the tuner knows what he is doing,will run every bit aswell as a pfc car.
i know of atleast 6 or 7 cars that are running 240plus without a problem and running deep into the 11s
Mine is one of those cars. There are many others that I know of who have run this way for some time now without any dramas. At this range I have seen every bit as much Horse out of a car with standard comp as Power fc. Once you go higher than this then sure you need a PFC, but you also need injectors, different turbos etc. It is a big step, but if you are not looking to go higher then this then in my opinion from what I have seen on the dyno there is no benefit from the power fc.
Just in the guy you choose to do the tuning.
vspecv,
Today is the big day. Tick tock. Good luck. (and I want a ride :D )
Mick.
vspecv,
Mick.
yep todays the day,its finished and ready to pickup,rebuild no2 is complete.
I'm a newby here so have a few questions relating to info in this thread, my apologies if it has been covered already.
where is this restrivtor you speak of?
how do you remove it?
does the factory ecu then account for the change in boost or do you have to get the car dyno'd/tuned?
i thought the r33 ecu was not programmable, therefore what can be achieved with an r33 by having it dyno'd?
thanks
Steve
Guest turbogtst
I am running modified standard cam gears set at 6 degrees advanced on the inlet and 6 degrees retarded on the exhaust, a rechipped R32 GTR ecu in my R33 GTR, 550cc injectors, stock turbo's, cat back exhaust with no cat, making 1.2 bar boost at 3800 rpm. I have had a power fc no better than a rechipped ecu same power results 250 kw at the wheels.
Y0880 - On the GTR you can run up to 1.4 but not if you intend to keep your turbos for a long time. I'm running 1 bar and have been safely for a while now and I think anything between 1bar to 1.4 is risky with the standard ceramic wheel.... especially in summer.
71LLA:
It is a small metalic ring that sits inside the vacuum hose on the way to the solenoid which restricts your car to the boost it runs stock. Hence the name
You pull off the vacuum pipe, and get pliers or tweezers and pull it out and reattach the vacuum pipe. Alternatively cut the part the restrictor is in (you can feel it).. and reattach the pipe.
The boost is not affected by the ECU here and there is no boost cut at this level... when you remove the restrcitor you get instant one bar boost.
400HP
Thanks for that, can you give me a clue on where *exactly* I can find this vacuum pipe? Seems to be lots of hoses under this bonnet.
And to confirm, once it's out that is it? No need to have anything done to the R33 ECU? Won't it run lean?
My digi cam is f*cked so I can't take a photo. Basically if you look on the left side of your car above and to the left of the plenum there is like a little gold cylinder about 2cm x 4cm. This is the solenoid. There will be two vacuum hoses going to this. One that goes from the bottom of it and one that goes from the side. If you feel around and squeeze the hose within the first 10 cm of the one that comes from the side you'll feel a part which has a small metal bit. Thats what yoiu need to remove.
Sorry this is the best descreiption I have of it.
Thats right. Remove... done.
  • 3 weeks later...
alright people.....I'm seriously confused. I have the car booked in to get the cam gears done but I am stoked to which brand to get. I rang Sub-Zero in Q.L.D yesterday and they advised me not to get the HKS gears because they only last 25 000kms....wtf????
My number 1 problem is that I have people telling me that the HKS gears last forever and that they are really good....but on the other hand I have people telling me not to use them because they are really really shit.
What should I do?
Sorry to be a pain in the arse but I'm not in favour of buying Cam gears and them lasting only 25,000 kms. I need your opinions and info!!
Thanks again
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
