300rwhp (225rwkw)... what does it take?
Guest Nismo_Freak
My target is 300rwhp w/o swapping the stock turbo. This would be 300rwhp in American terms if that means anything, I have yet to figure out if there is a difference. What would I need to do this without swapping the turbo and how reliable would it be. I will have a large aluminum radiator for sure since my stock 240SX one would explode.
https://www.sau.com.au/forums/topic/6961-300rwhp-225rwkw-what-does-it-take/
  • Replies 40
I think 225rwkw would be very easy to achieve, to begin with.
My '95 R33 GTS-T
192rwkw @ 12psi
168rwkw @ 8psi
Mods:
Cat back exhaust
HKS Pod Filter
FMIC
2 Stage boost controller
I was only using 96 octane and havent had a tune or oil change in 7,500km either.
http://skylines.pnc.com.au
Guest Nismo_Freak
Ok heres what I have planned:
RB25DET
Hybrid FMIC w/ Custom Piping
Apexi GT-Spec Exhaust (3.75")
Custom 3.5" Downpipe to Exhaust (No Cat)
Apexi Intake w/ Homemade Cold Air Box
Greddy Profec B Boost Controller
Walbro 255Lph Fuel Pump
HKS SSQV BOV
Single Disc 6-puck Clutch
Cusco LSD (1.5 or 2 way)
Apexi Turbo Timer
Greddy Boost Gauge
Redline 75w140 Gear Oil in Tranny
Amsoil 10w30 in Motor (too thin?)
Boost im prolly gonna set at 12 psi unless the turbo can handle 14psi and be reliable for a while.
Edit* - Replaced S-AFC w/ POWER FC
sounds very good nismo freak which engine is it the seies 1 engine or series 2 engine ?
series 1 engine you can run 14 psi series 2 I would stick to 12 psi
ben I'm not doubting that was the figure you made but some dyno's are very optimistic thats ~~~
drdrifts old car only made 170 rwkw but ran a 108 mph at the drags which says closer to 200 rwkw if you get what I'm, saying some read high some read low its hard to campare apples with apples
meggala
Nismo_Freak
So far I have the following mods
3" custom dump and front, high flow cat, 3" N1 style cat back
Hybrid FMIC with 3" pipwork
Pod with cold air partition
Power FC with Boost controller
Turbosmart BOV
9 button clutch
plus (irrelevant to this thread) various suspension, TT, boost guage, etc
On a dyno dynamics dyno, made 260rwhp at 0.85 bar (254 at 0.7 bar) when the clutch started slipping and the power curve flat lined. Of further concern was that the AFM maxed out at 4500rpm and the curve 'fell over'. I am sure with the clutch now fixed and a Z32 afm on its way, that I will be able to get a little more, however from what I have read of other peoples experience, and my tuner's advice, a stock R33 turbo would not be able to support 300rwhp (about 408bhp it think). As for your fuel pump, not too sure you would need to replace it as my injectors were running at 77%, perhaps you could get away with just a fuel pressure regulator instead? Also of a bit of concern at the moment is traction. I am running 255/40/17 goodyear revspecs and although they are one of the better gripping tyres, power oversteer (which is alot of fun) and straight line traction off the mark are starting to become issues.
Some food for thought anyways
Steve
EDIT: Just notice you are talking dynojet type dyno? I believe that the figure I quoted above would probably make it past the 300rwhp if it was done on a dynojet - from the comments I have read in other threads about the differences between dynodynamics and dynojet.
My mods,
R33 gtst
3" turbo back exhaust.
No cat
custom FMIC
Brass button clutch
higher boost on standard turbo.
HKS airpod.
On a dyno dymatics with 11psi my car did 197rwkw
On a dynodymatics at a skyline meet with 13psi my car did 180rwkw.
This should show the inconsistancy of the dynos.
I think that 180rwkw is the correct figure (and meggala can vowge for that).
Guest Nismo_Freak
Ok .... thanks for the info. I need to get a brandname on the clutch. What would hold alot of power and not slip while being cheap and streetable? Also I forgot to include I would run a Z32 MAF. I have also been looking into a pulley kit for the RB since on the VG30DETT UR Pulleys dynoed another 30hp @ the wheels (Dynojet).
You dont get nothin for nothin Nismo_freak :(
300rwhp your gonna need a 5puck bruss button clutch minimum or twin plate if u are gonna drag race fairly often.....
I have just under 300hp and cooked my 2500lb clutch last night at the drags on 2nd run of 2nd outing (clutch is 3 months old)
I agree with Macka, getting the 300rwhp isn't that difficult, but having reliability aswell is not so easy. At 260+hp you may well have to look at a heavy duty or twin-plate clutch, weak points in the engine such as pistons may start to show themselves.
But to get the 300rwhp is going to require you running the turbo at stressful levels. Even though the turbo can just support those levels it is not going to last particularly long at 1bar.
Just some things to keep in mind.
See'ya:burnout:
Sorry ill butt in if Megs cant get online for awhile...
GODF4Th3R Series 2 came out with a Plastic impeller turbo wheel which spools faster but in turn can break away under higher boost!
Croat Your going to be paying $1500-$1800 for a good quality Highflow which is now starting to prove a very good move for alot of owners...no oil or water line changes, no dump pipe or compressor inlet or outlet changes which saves alot of $$ which people sometimes dont consider..
Hope i didnt butt in!
Cheers
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
