I dono why'd you give up the a31 front end though... maybe for a 180 front..
There was a s14 fronted cef posted up in this section some time ago now and I think most people didn't like it. I reckon it could be ok but if anyone finds photos please post front and back and side if possible.. It's pointless seeing a s15 fronted cef when it just looks like a s15 from the front :)
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289194
hahaha that laufiro is about as NZ as they come, matt black paint, workshopX frontbar
call me the biggest playahater ever but the front fender doesn't link up to the rest of the panel work properly ie: the "a" pillar
not usually a big concern but this could cause rust if not sealed properly when rain leaks through those cracks, laurel and cefiro fenders are notorious for rust apparatnly
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289215
you mean like an N13 pulsar front bolted onto a brandnew nissan pathfinder?
or or what about an 80's CA nissan EXA bolted onto a le man's nissan R390 race car?
the possiblities are endless... simply endless...
They all sound good to me, but why not swap it around, bolt a Pathfinder front to a N13 pulsar? :)
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289263
Anything R34 is pretty horn IMHO, I want a R34 kit for my R32 like this one at Garage-13:
Click for full-size
But since it's "from $4490" kinda hard to justify on a car not worth much more than double that, factor in re-spray and i think it'd only be worth it on a R32 GTR.
But i can dream. *sigh*
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289437
roflmao garage-13's R324
its made by Bee-R and I think that's garage-13's pipedream for suckering someone into buying the original so they can copy it.
and the R34 on R33 unit they sell is a URAS one.
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1291012
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
