I have just installed an Apexi Super Suction with super intake air filer to my stagea. To fit I had to take the radiator overflow catch tank out, and have a temperary one for now. Have other people had the same problem? Does anyone know what I could replace it with. I measured 3/4L that it needs so I need to find a small one that can fit somewhere .
What have other people done/used?
I will have to enclose the POD at some stage for more cooler air.
You shoulda just bought the rampod by itself. It just bolts omto your airflow meter. I have one. I'm gonna buy a carbonfibre box for it to sit in.
You can easily make one yourself. Use cardboard to stencil it first, then get hold of some 3-5mm alluminum and cut and bent to shape. To join the lid to the sides (and sides to body) you can use L-brackets with a bolt and threaded hole.
PS: You only need to make 2 sides and this could be done out of one alluminum piece. The other 2 side are formed by the car body.
Note: A pre-fabricated air box my not be suitable, as they are designed for one type of air pod, thus you may have to modifiy it to fit. DO NOT ATTEMPT TO MODIFY CARBIN FIBRE.
(Unable to take better pictures as my car is currently at the paint shop)
I think will look at buying a smaller plastic overflow tank from nissan first, if not then i'll do what Al said and make a custom one.
Also I am going to swap my air intake snorkel and replace it with a GTR one as it is wider and closer to the front and edge of engine bay so it will be right near my air filter. Ill have pics in a few weeks.
Emanuelt....
I love that duct. I'm trying to do a section in the standard duct at the monent.....
Are you using your standard duct anymore?? Can I borrow/buy it from you?
I need a prototype to play with.
  • 1 month later...
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
