Hey everyone,
Can someone please tell me how I can fix a small problem with my car. I own a R32 4 door (rb20det) as I drive along my car will start dieing, the revs will drop and sometimes it will stall or suddenly pick up again. Sometimes it will stall and will not start after about 10 mins of trying, I have changed the air flow meter twice. I could go ahead and take my car to tokyo toys in which they forward the car onto a place down the coast which do a dyno read outs and hopefully find failures in my engine, but for it to do that my car needs to be broken down which most of the time it does not do.
I live in brisbane and was wondering if anyone could help me
thanks guys
https://www.sau.com.au/forums/topic/6994-need-help/
Sik32,
The revs dying then picking up again sounds like it may be a fuel issue. When you say that sometimes you can't start the car for 10 mins, can you be more specific. Is it flooding or not enought voltage to cause a proper spark?
There are a number of things it could be, AFM is just one of them, but having replaced it twice it seems unlikely. The coilpacks on the RB series can start to play up when they get hot, and wont provide sufficient spark for combustion.
If you provide us with more details we will try and narrow your search down.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-103399
To GTS-t VSPEC,
Thanks for the reply, when i drive along and the engine dies then I pull over and turn the igniton to start the car. It just windes over , I wait 10 -15 mins then it starts. Sumtimes it will start straight away whilst still rolling.
Also as i drive along a highway the engine nearly dies I hold down the accelerator and then it just picks back up and goes like normal.
Good luck ,
ps. Im getting a datastream print out for it on monday do u think this might find this intimiting problem
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104169
Sik32,
Its difficult to tell with an intermitant problem such as this, I would be leaning towards faulty coilpacks as the problem. The would cause a miss which could cause the revs to drop and stall the car. This is can be related to the engine being hot, hence the reason its intermitant.
It might be worth taking the coil-pack cover off and having a look at both your coilpacks and sparkplugs, if something is wrong then you might have a burn spot around the coilpack cover, or one sparkplug might have a burnt appearance.
I take it you haven't noticed it missing whilst driving or difficult to start in the morning? Do you have any fuel management running?
I hope we can start to narrow this down further, but start looking there as it won't cost you anything if you do it yourself.
See'ya :burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104330
Guest Boxhead
im not sure if this will help or not..
but.. when i was driving my na behind dave and another guy, a mini cruise, they were going medium, so basically to keep in eyes distance, i had to go flat out..
we pulled over somewhere.. leavin car runnin, just to get out and decide were we are going, which way etc, we decide, i go back to my car, and suprisingly engine is off.. i try to start it.. and it wont start, starter motor is workin, can hear that etc, but engine wont kick over, however... the heat gauge is showing in the middle(as per usual..) you must keep in mind it was a bit of a bloody hot day..
anyway, after waiting ten minutes.. car did start again, but you could here it miss firing in higher revs.. like, if i put foot down, it would misfire etc.. but.. if i graduly went up to those revs it wouldnt mind..
I got home, and my grandfather who is an ex mechanic, said it sounds like an over heatin problem with spark plugs or coil packs etc check your plugs.!!!
i know myn were platinum and were almost ready for a new set..
i hope this helps mate
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104382
Its me again,
I thought I would clarify what i mean by what happends when the car breaks down, the engine actually dies its not a matter of revs dropping , although being in the driving seat u see the revs lowering but if your engine is going to stop obviously your revs are going to drop.
I know its a electrical problem such as a sensor of some sort, is there any sort of check on sensors that I could do ?
what sensors could cause this.
ps monday datastream test hopefully will shed some light on the issue.
Keep you posted.
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104491
If you have a factory computer and a faulty sensor then you will most likely be able to get the fault code out of the computer, you can either do this your self or get a tuner to do it.
I think the codes are available somewhere in a thread on this forum, or you could go to Meggala's website as I'm sure it will be there.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-104542
I'd imagine that suggests that it is not one of your sensors, therefore I think that coilpacks are the most likely culprit.
I don't know if anything will show up on the datastream test if the problem is intermitant, but good luck anyway.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105055
Praise from the heavens above.
Finally, I took my car to Gavin Woods Auto Tech and the problem was that my car had to break down in order for him to work out the problem so i arrived at his workshop at about 10, I gave Gav my keys and he went for a spin I didnt ask him if it broke down on the drive but I doubt it did. Anyways he pulls into the workshop and the car is just idleing next minute its spluters then dies. I knew that this was gonna be it, probly the first time I wished for my car to break down and it did. He had the datastream computer hooked upto my car and he knew what it was straight away. The fuel pump is officially f***ed, Gav hooked up a fuel pressure gauge to my car and it was flowing about 30 on his gauge after he put his foot down it didnt really move and his eyes nearly popped out of his sockets. It is meant to be up around the 60 to 90 when hitting boost causeing my car to lean out dangerously and the computer says naaaaar stuff this and goes out for lunch.
I am now ordering a 500hp rating pump and on the way to havin a car which I can drive everywhere without being afraid of stoppin at light and or driving down the coast without being rear ended.
Thanks very much to everyone for your help especially GTS-t VSPEC,
take care guys.
:jump: :jump: :jump: :jump:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105710
R324DRIFT,
Great to hear that your car is now fixed, and you were very lucky that it died in front of him, otherwise you would have had to wait until it had officially died before you realised.
I hope you have many km's of hassle free driving.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/6994-need-help/#findComment-105845
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
