i got quoeted $291ea. tyre 225x50x16 on my stock gtst rims. sum 3000 brand tyres.
 thats fitted n balanced by the way. Beaurepairs
For that much they'd want to be some pretty damned good tyres, I suggest you shop around, you should be able to get good (not excellent) rubber for half that amount.
The Hankook Ventus K104's seem to have a good rep. as bargain quality tyres and people are picking up 235/45/17 for around $180.
They will fit, as in bolt on, but they're no good as the offsets will be all wrong.
I had R32 GT-R rims on my R32 GTS-T with 225/50/16's and they fitted great.
( I then got my gaurds rolled and now have 17 x 8 front with 235/45/17 fitted and 17 x 9 back with 255/40/17 fitted and she looks very fat indeed ).
With the GTR32 Rims having a bigger or smaller however you put it,
On a R32 gtst with stock rims you'll notice that the rims actually sit inside and under the guards, whereas for GTR32 rims the offsets are like +30 (or something from memory) so ALL for rims will sit further out from the hub and if you car is lowered with no camber your wheels will hit the arch/guards when you go over a bump or turn hard into a corner. BUT if you have standard shocks and stock ride height you won't have the Guard hitting problem.
BUT keep in mind its illegal to have your wheels sitting outside your guards, like if you stand next the side of the car where front wheel is and look straight down if you see the tyres sitting out pass the guards it illegal (or defectable).
This is my understand and STUPID/wrong offsets because i've had 2 sets of rims which didn't fit on my car PERFECTLY. BUT someone with a R32Gtst with GTR32 rims can clarify this.
R32gtst rims are 16 x 6.5" (you can fit 225/50/16 or 205/55/16)
R32GTR rims are 16 x 8" (you can fit up to 235/XX/16 maybe even a 245 dunno but standard i think is 225/50/16 compared to the 205/55/16 on gts rims)
i hope that helps. :)
my 2 cents
Going from 6" +40 to 8" +20 means:
From the Wheel Offset Calculator
The clearance from stut housing to the inside of the wheel will be 5mm LESS
The outside edge of the wheel will EXTEND an extra 45mm
Considering you want to at least TRY and keep things even, so as no to screw your suspension geometry up too bad, GTR rims don't qualify. +32 to +35 is far more suitable for 8" rims.
Ash.
Would you know if the R33 GTR rims are the same offset.
I've seen one set on a R32 GTST, they looked like they sat under the guards, only just.
Not sticky outy like the R32 GTR rims I've seen.
32 GTR rims looked illegal to myself, R33 GTR's didn't.
Doesn't mean there not illegal though.
Ash.
Hey Joel, I'm not really sure, but i *THINK* offsets are pretty much the same across GTR's and GTST's regardless of R32/33/34, what you describe could have been the fact the R33 has 17's and less "tyre bulge" than the 16's of the R32.
I think people just need to retire themselve to fact that while GTR rims will fit GTST's in most cases, it doesn't mean they're correct or such a great idea handling wise, regardless of whether or not they're legal. Sorry.
Ive got 16" rims on mine....
the rears are 8" wide with 225/50/16 (offset is +38)
the fronts are 7.5" wide with 225/50/16 (offset is +25), also
the car is lowered and sitting about an inch or so above the top of the tyre.
The car hasnt had a proper wheel alignment in a very long time (read camber is off) and the tyres wear on the inner side.
The tyres clear hitting the guard by about 10 to 15 mm or so, and if it were given a proper wheel align. id say it would be close, but still not hit....
  • 4 weeks later...
Hi Ash,
could you please elaborate as to why R33 GTR wheels would not be beneficial to the handling on a R32 GTS4?
is it to do with the wheel alignment now being wrong? should be easily fixable...
I just got some today but haven't had the time to fit them yet.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
