  • Replies 61
Unlike the rb20det it makes a difference if I boost it around everywhere.
The RB20DET would always get 470km's to a tank of juice.
The RB30DET if heavy with the foot will get a minimum of 430 and a best of 520 with a light cruising foot.
Nice result there Joel!
Can't wait to get the last few parts to go onto my RB31. Then I can get it all tuned!
Just have to get the turbo highflowed (RB25 S2 turbo) and decide on what injectors I want to go. Not sure if I want 550's or 600's. They are both the same cost.
Thats not too bad hey. I guess also with still running the rb20 turbo its on boost 90% of the time.
Im getting about 570kms to the tank atm, so I guess if I did it with my pansyarse driving I should get 500kms a tank easy. Its fair for a ballistic motor :)
must be a rb20 thing.. i put my foot down everywere always get around 400 to a full tank 300 by 1/4 left.. no matter how i drive :) weather its like i stole it or miss daisy but meh hopefully a rb30det will be in my engine bay by the end of the year.. (if i get my act together n start working again)
nice results tho
Nice work cubes.
I thought u would have budgeted to get the big snail on there so it could have all gone on their at once.
I dont know how you are getting such good fuel economy there, I am lucky to get anything over 300km to a full tank driving like a granny to work everyday
Yer not sure on the fuel economy, A couple of things I can think of?!?
Accelerating around slowly and boost starts to build I lick the throttle back a little to let the BOV bleed the boost.
RB20 general driving I used to change up at around 3000rpm.
RB30, I change up just over 2000rpm, some times i throw it in a high gear and let the torque lug slowly to the speed limit.
What injectors are you running?
Spray patterns and good atomisation make a noticable difference to economy.
Inasnt,
Its some where in the Settings Inj menu. The ms. Unsure if it states injector correction or not. :rofl:
Out of curiosity I've done a few little calcs.
After looking at the peak power it really is approx 175rwkw which was made from approx 4500rpm to 4950rpm.
The 176rwkw was simply a little peak in the graph, I don't consider it a power figure. If that makes sense. :)
So lets say 4500rpm is where the peak power was made.
RB30DET - 4500rpm to 4950rpm
flows the same air as an
RB20DET - 6775rpm to 7400rpm
My old RB20DET made its peak power figure of 164rwkw (stock ecu but) on 1bar of boost at 7000rpm. I thought 7000rpm was a little high for a stocker so it may have been a dyno operator error. Rev's flick quickly around that point so it may have been 6800rpm or even 6500rpm (more likely)
Either way it gives a general idea on the engine airflow differences between the two motors.
No wonder the turbo drops power after 5000rpm. :(
If this turbo was on the rb25det I would expect it to make its peak power between 5425rpm to 5925rpm.
Has any one got a dyno graph of their RB25 on the stock RB25 turbo, where it makes its peak power or if the graph rounds out slightly?
By RB25 factory specs (6200rpm) I would expect peak power on the 3ltr with the rb25 turbo to be around 5150rpm then maybe round off and possibly hold a figure close to that for another 500rpm or maybe hold an average power figure over 500rpm with the 5150rpm being the in the middle of that distribution.
It would be interesting if this theory were to hold true, and if VCT on the RB25 RB25 head actually extends the peak power figure on the 3ltr, hence improving VE a noticable amount in the top end over the RB25DE N/A Cams.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
