  • Replies 61
Unlike the rb20det it makes a difference if I boost it around everywhere.
The RB20DET would always get 470km's to a tank of juice.
The RB30DET if heavy with the foot will get a minimum of 430 and a best of 520 with a light cruising foot.
Nice result there Joel!
Can't wait to get the last few parts to go onto my RB31. Then I can get it all tuned!
Just have to get the turbo highflowed (RB25 S2 turbo) and decide on what injectors I want to go. Not sure if I want 550's or 600's. They are both the same cost.
Thats not too bad hey. I guess also with still running the rb20 turbo its on boost 90% of the time.
Im getting about 570kms to the tank atm, so I guess if I did it with my pansyarse driving I should get 500kms a tank easy. Its fair for a ballistic motor :)
must be a rb20 thing.. i put my foot down everywere always get around 400 to a full tank 300 by 1/4 left.. no matter how i drive :) weather its like i stole it or miss daisy but meh hopefully a rb30det will be in my engine bay by the end of the year.. (if i get my act together n start working again)
nice results tho
Nice work cubes.
I thought u would have budgeted to get the big snail on there so it could have all gone on their at once.
I dont know how you are getting such good fuel economy there, I am lucky to get anything over 300km to a full tank driving like a granny to work everyday
Yer not sure on the fuel economy, A couple of things I can think of?!?
Accelerating around slowly and boost starts to build I lick the throttle back a little to let the BOV bleed the boost.
RB20 general driving I used to change up at around 3000rpm.
RB30, I change up just over 2000rpm, some times i throw it in a high gear and let the torque lug slowly to the speed limit.
What injectors are you running?
Spray patterns and good atomisation make a noticable difference to economy.
Inasnt,
Its some where in the Settings Inj menu. The ms. Unsure if it states injector correction or not. :rofl:
Out of curiosity I've done a few little calcs.
After looking at the peak power it really is approx 175rwkw which was made from approx 4500rpm to 4950rpm.
The 176rwkw was simply a little peak in the graph, I don't consider it a power figure. If that makes sense. :)
So lets say 4500rpm is where the peak power was made.
RB30DET - 4500rpm to 4950rpm
flows the same air as an
RB20DET - 6775rpm to 7400rpm
My old RB20DET made its peak power figure of 164rwkw (stock ecu but) on 1bar of boost at 7000rpm. I thought 7000rpm was a little high for a stocker so it may have been a dyno operator error. Rev's flick quickly around that point so it may have been 6800rpm or even 6500rpm (more likely)
Either way it gives a general idea on the engine airflow differences between the two motors.
No wonder the turbo drops power after 5000rpm. :(
If this turbo was on the rb25det I would expect it to make its peak power between 5425rpm to 5925rpm.
Has any one got a dyno graph of their RB25 on the stock RB25 turbo, where it makes its peak power or if the graph rounds out slightly?
By RB25 factory specs (6200rpm) I would expect peak power on the 3ltr with the rb25 turbo to be around 5150rpm then maybe round off and possibly hold a figure close to that for another 500rpm or maybe hold an average power figure over 500rpm with the 5150rpm being the in the middle of that distribution.
It would be interesting if this theory were to hold true, and if VCT on the RB25 RB25 head actually extends the peak power figure on the 3ltr, hence improving VE a noticable amount in the top end over the RB25DE N/A Cams.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
