  • Replies 124
Well as i said i was unable to make it due to having to go check out my cefiro and decide on whether to give em the 'go ahead' with the engine swap. I did make it down to the Shell servo to say hi to Nissaner & CC.
I think next time we need to make the organisation a bit better. Sorry if it caused any probs.....i did say I was gonna be a 'no show'.
Was good to put some names and faces to fellow ceffie owners! :uh-huh:
I decided after taking my ceffie for a spin that it really does need a new engine.....running like an absolute dog....about 40% power loss....so in goes a new engine & hopefully pickup locked in for Sat fortnight! It also gave me an opportunity to 'identify' a few other issues........me thinks it needs the guards rolled considering it was rubbing harder than a $2 whore! :werd: Anyone had this done to their cefiro??? Cost?, workshops to do it!? :confused: Apart from a couple of new tyres and getting used to driving with a cage, all should be good to go!
Neways thanx again to Tom for letting me whore along for the ride in his ceffie, to the workshop and our round trip around Sydney ahahahahhahah :cuddle:
Ando
Heya nissaner - Mate sorry but i was struggling enuff to get the trade plate off the dude, let alone ask him questions......there was literally a line up of customers. Am talking to em this week so will pop the question then.
Ando
Ando
you want the guards rooled just on the inside or you want some flare looking things? if you just want to roll the inside, then 7 day tyres are ok if you want to pay too much, $50 two guards.
parra rd, left hand side when heading into the city, btn james ruse drive and duck st (autobarn auburn)
Well what can I say guys haha
5 of us turned up to Penrith and waited 2+ hours and no one else showed!  Was good to meet some new owners though so I was pretty happy.
My sincerest apologies for you guys waiting for 2hrs+.
I was running late to space station and decided by the time I got there I wouldn't make it to Penrith cos noone from space station was going there and plus I wouldn't make the time.
Little did I know you guys would wait 2hrs+ - oh well next times the trick!
5 cars sounds like a great number so apologies again for missing it guys hope everyone had fun!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
