Hey Guys,
Im interested in getting an electronic boost controller
I went into AutoBarn and seen a brand called Gizmo
They were selling them for around $480.
Any know if their any good or crap.
Any suggestions on which electronic boost controller is recommended.
Nothing over $600.
Cheers ;)
https://www.sau.com.au/forums/topic/70249-electronic-boost-controller/
']you can get a Apexi AVCR, for brand new for $600,
Hey, well the greddy profec spec b ii does the same job
Apexi may have more features but i dont care for features
As long as its reliable and does the same job im happy,
I got a quote around $400 for the greddy boost controller
What do u think.?
What do u think.?
apexi one is good but, it isnt good unless setup right. I have heard only hood things about the profec ebc, i own a profec A and it works wonderful, i belived spec b, is daul sol and is very good
What do u think.?
If you just want someting cheap and reliable why not go for a BLEED VALVE
almost guaranteed never to break down...works without eletricity too :)
bleed valve is not exactly relibable. a cheap ebc will serve its purpose and be accurate. i got a 2nd hks evc for $250 and it works awesome, i had a problem with it last week but it was just loose wiring. does awesome boost control
for something that needs to be reliable in it's performance such as a boost controller, i think you're best to go for a well known unit.
the jaycar boost control is fine if you have the time and knowhow to set it up, but if you're like me and just want something that you can get fitted and basically have no worries with go for AVCR or SBC idIII.
both can be found for around 570-630 new.
get the profec , or you can get a blitz ssbc for about 400 also .
i got a second hand old blitz ssbc off the forums , here . it didnt work . luckily the guy gave me back most of my money , got a 2nd one of the same type and replaced the faulty control unit . so it cost about 200$ all up and ive got some spares just incase .
I generally email the instructions and pics to ppl, as I can't get the pic's up here (too large). Any ideas?
For anyone else interested, here are the photo's/instructions DAN00H was talking about.
Pics to be read in conjunction with word doc
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
