Has anyone done before/after dyno with this exhaust cam gear yet?
Is an aftermarket ECU 'required' for these or is it only an 'advantage' ?
I'm looking for little things to get me up over 210rwkw on the Std ECU/Turbo and this looks like the next step.
Whats the typical cost to have these installed + tuned at a dyno shop ?
Edit: I was also liking the rice factor of the HKS Purple+Blue :P
  • Replies 74
Hi Guys, I bought a set of Jun adjustable cam gears on the forum a few weeks ago. They appear to be standard Nissan GTR pulleys with the centre machined out and replaced with a steel adjuster. If they are standard Nissan teeth they will obviously last as long as they would unmodified, provided the centre line of the adjuster is lined up properly during the machining process. They have 5 adjuster bolts which should provide more than sufficient retention.
UniqueAutosports sell modified standard pulleys for $185 each for the standard weight and $195 for the lightweight ones. So, as long as they have the same accuracy of centring there should be no problems with theirs either.
If you are not looking for looks (the HKS ones do look trick) or extreme lightweight, these are viable options.
Hope that helps.
I wouldn't bother loosing the VVT until over 250rwKW, and use the cam gears in conjunction with better cams.
Steve, Thanks for the link, what would the postage be? I have worked it out before, and the group buy idea is better as only one postage cost is needed.
See'ya:burnout:
GTS-t VSPEC,
costs:
http://www.greenline.jp/info.php
says:
The following table indicates the shipping costs to Zone 2, which includes Australia, New Zealand, USA, Canada and any country in Europe. For other countries, please contact [email protected]
Base rate (up to 1 kg) ¥3990
For each 500g more than 1 kg ¥525
Works out at about $55AUD for the first kg (ouch), but $14.50 for every kg there after, which is a bit better.
when were you thinking of getting these? Soonish I hope. I'm after 1 (for now - maybe 2 later), and wouldn't mind jumping on the group buy bandwagon
Cheers
Steve
Steve,
Can you find out the weight of the cam gears, plus are there any additional taxes that need to be pay for goods coming into Australia?
I can buy them whenever, just trying to find somewhere which is cheaper than I can get them here.
See'ya:burnout:
Not too sure about taxes, have you had a chat to customs. From most of the feedback I have read, it seems that if it is under $1000AUD they dont seem to worry a heap - never know for sure though. I did get my turbo through, but the guy at the other end put it down as about $380AUD - they opened it for inspection, but didnt hit me any duty.
I will drop them a line, and ask about quantity for group discount and unit weight.
Steve
so on a car with a big turbo (like a HKS 3040) and the usual other mods like fuel pump, injectors, engine management (I have HKS FCONV, VPC and PFC-FCON), exhaust, intercooler. Would it be worth removing the VVT and getting a cam gear for both inlet and exhaust? It's an RB25DET, and what sort of cams should i go for? 256 Duration and 8.8mm lift? or bigger, to something like 264 duration and 9mm lift? What would the difference be between the two cams?
I'm liking the sound of the Toda gears myself! The top end power is pretty good so i'm more after some street usable mid-range at this stage. I've also read on the other CAM thread that you might be able to get the inlet cam slotted to allow adjustment and still keep the VVT.... is this true or not worth it?
Thanks
Andrew
GiJOR33,
With a setup like that, then yes I'd do both cam gears. Sounds like a similar setup to what I'm going for.
Cam's I'd go for the 264's, but the 256's are also very good.
Yes, it is possible to slot the existing gear, but the VVT doesn't have sufficient impact to make it worthwhile doing at big horsepower.
See'ya:burnout:
A guy at work machined out the centres of my steel gears and replaced them with adjustable alloy centres (which he made as well). They allow +/- 4 degrees adjustment and only cost me $17 for the materials and a slab for the labour.
Guys go to a machining company with a design and all your standard gears in bulk and it will cost you **** all to get them modify.
Why buy wanky brand name gear? It doesn't make your car go any faster and it costs a fortune.
Pawley, I think the UAS ones are made exactly the same way as Rowdyr32's are. That would mean they have like a $150 markup on them. Which I guess isn't over the top, but if you look around enough you can probably get it done cheaper (let's all ask Rowdyr32's mate if he wants to do some more for us ;))
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
