Has anyone done before/after dyno with this exhaust cam gear yet?
Is an aftermarket ECU 'required' for these or is it only an 'advantage' ?
I'm looking for little things to get me up over 210rwkw on the Std ECU/Turbo and this looks like the next step.
Whats the typical cost to have these installed + tuned at a dyno shop ?
Edit: I was also liking the rice factor of the HKS Purple+Blue :P
  • Replies 74
Hi Guys, I bought a set of Jun adjustable cam gears on the forum a few weeks ago. They appear to be standard Nissan GTR pulleys with the centre machined out and replaced with a steel adjuster. If they are standard Nissan teeth they will obviously last as long as they would unmodified, provided the centre line of the adjuster is lined up properly during the machining process. They have 5 adjuster bolts which should provide more than sufficient retention.
UniqueAutosports sell modified standard pulleys for $185 each for the standard weight and $195 for the lightweight ones. So, as long as they have the same accuracy of centring there should be no problems with theirs either.
If you are not looking for looks (the HKS ones do look trick) or extreme lightweight, these are viable options.
Hope that helps.
I wouldn't bother loosing the VVT until over 250rwKW, and use the cam gears in conjunction with better cams.
Steve, Thanks for the link, what would the postage be? I have worked it out before, and the group buy idea is better as only one postage cost is needed.
See'ya:burnout:
GTS-t VSPEC,
costs:
http://www.greenline.jp/info.php
says:
The following table indicates the shipping costs to Zone 2, which includes Australia, New Zealand, USA, Canada and any country in Europe. For other countries, please contact [email protected]
Base rate (up to 1 kg) ¥3990
For each 500g more than 1 kg ¥525
Works out at about $55AUD for the first kg (ouch), but $14.50 for every kg there after, which is a bit better.
when were you thinking of getting these? Soonish I hope. I'm after 1 (for now - maybe 2 later), and wouldn't mind jumping on the group buy bandwagon
Cheers
Steve
Steve,
Can you find out the weight of the cam gears, plus are there any additional taxes that need to be pay for goods coming into Australia?
I can buy them whenever, just trying to find somewhere which is cheaper than I can get them here.
See'ya:burnout:
Not too sure about taxes, have you had a chat to customs. From most of the feedback I have read, it seems that if it is under $1000AUD they dont seem to worry a heap - never know for sure though. I did get my turbo through, but the guy at the other end put it down as about $380AUD - they opened it for inspection, but didnt hit me any duty.
I will drop them a line, and ask about quantity for group discount and unit weight.
Steve
so on a car with a big turbo (like a HKS 3040) and the usual other mods like fuel pump, injectors, engine management (I have HKS FCONV, VPC and PFC-FCON), exhaust, intercooler. Would it be worth removing the VVT and getting a cam gear for both inlet and exhaust? It's an RB25DET, and what sort of cams should i go for? 256 Duration and 8.8mm lift? or bigger, to something like 264 duration and 9mm lift? What would the difference be between the two cams?
I'm liking the sound of the Toda gears myself! The top end power is pretty good so i'm more after some street usable mid-range at this stage. I've also read on the other CAM thread that you might be able to get the inlet cam slotted to allow adjustment and still keep the VVT.... is this true or not worth it?
Thanks
Andrew
GiJOR33,
With a setup like that, then yes I'd do both cam gears. Sounds like a similar setup to what I'm going for.
Cam's I'd go for the 264's, but the 256's are also very good.
Yes, it is possible to slot the existing gear, but the VVT doesn't have sufficient impact to make it worthwhile doing at big horsepower.
See'ya:burnout:
A guy at work machined out the centres of my steel gears and replaced them with adjustable alloy centres (which he made as well). They allow +/- 4 degrees adjustment and only cost me $17 for the materials and a slab for the labour.
Guys go to a machining company with a design and all your standard gears in bulk and it will cost you **** all to get them modify.
Why buy wanky brand name gear? It doesn't make your car go any faster and it costs a fortune.
Pawley, I think the UAS ones are made exactly the same way as Rowdyr32's are. That would mean they have like a $150 markup on them. Which I guess isn't over the top, but if you look around enough you can probably get it done cheaper (let's all ask Rowdyr32's mate if he wants to do some more for us ;))
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
