  • Replies 154
Well I want to go for a cruise, and I know Ewen and Andrew (skygtrline) seem keen for a cruise... so Im goin for a cruise :) Anyone who wishes to come along is more than welcome.
-- MEETING DETAILS --
WHEN: Saturday 21st May, 9:00AM for 9:30AM departure
WHERE: Gull service station, Monaro Highway Hume.
-- WHERE IM GOING --
Cruising down through Cooma and Jindabyne, then onto Alpine way up to Charlottes Pass via Perisher Blue. Yes it will be cold, yes if its raining it will be icy and I probably wont go. Other than that, roads should be fine, theyre good roads as well ("serviced" every year), nice and wide with open sweeping corners. Theres also BP Ultimate availible on both Cooma and Jindabyne for all your petrol supplies (albeit, usually 5 - 10c per litre more than what we pay here). Should get to Charlottes Pass by 12:30PM, dick around, frolick in the snow, then head back towards Jindabyne for some food and a drink/beer/whatever.
If you want in, just say so here and will see you on the day :)
EDIT: Theres also a $16 cost per vehicle to enter the national park. So its not "cheap" as compared to a small cruise to Orroral etc, but it is a fun drive, nice and scenic and long, and cold weather = cars like to boost more :D
EDIT AGAIN: At this point in time, I have posted this on Shogun forums as well and would prefer it not to go onto any other forums. There -WILL- be police heading down to cooma at least, and possibly even up to Jindabyne (ski season starts 2 weeks after this cruise, so they will be upping their presence) and trying to avoid any unsocial behaviour some other unamed clubs have displayed in the past. The police down that way are a very friendly bunch, and will not have any problems with us as long as were not doing any obvious forms of dangerous driving (aka "FULLY SIK DORIFTO BRO~!")
Can't apply for time off? :)
no mate, no can do. Saturdays are our biggest day of the week, and what with my chicken pox (3 weeks off) taking my b'day off last week and going to Europe for 6weeks in July, im probably pushing my luck asking for a saturday off to go for a cruise.......sigh
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
