  • Replies 154
CRAP!
i wont be making it guys. change of plans. i've got finish filming a short film for my GF's CIT project. was supposed to be finished last weekend, but we didn't. well have fun. i might come to gull to see you all off anyway. :wavey:
Hi everyone...first post here.
I've done a track day with you blokes before, or was it skylinesnsw or are you the same bunch? From memory Franks was there.
I got an XR6T, and Nik mentioned this cruise to me on another forum, so looking forward to it and see you all in the morning!!
Depending on what time we actually get to the destination, I might be back tracking and heading down through thredbo, khancoban, cabramurra, kiandra adaminaby and back home either via dirt from Adaminaby - Tharwa or through Cooma. Anyone is welcome to tag along :)
Ivan
