  • Replies 174
hey guys I am back and badder than ever
I am a very wanted woman you know and have been recieving pm's Australia wide from desperate males looking for some HCSC action
1. Are you hot?
2. Do you put out?
3. do you dress really 5lutty?
4. How much do you weigh?
5. Do you have good teeth?
6. are you a girl?
Even though it is very likely you are some 200kg bald naked samoan man.
1. Are you hot?
2. Do you put out?
6. are you a girl?
1. and how :uh-huh:
2. you must go cruising with me first to find out big boy
3. only when cruising :P
4. 52Kg
5. I have all of them still, why did you want to put something in my mouth?
6. yes .. yes I am and don't pretend like you haven't met me
Oh yeah I remember now, you were in that furry jacket that night when you were out with nick.
Are you 18 now?   About bloody time.
Hahahaha, I take it all back HCSC is actually hot.
I am 19 all grown up and have been legal for three years now
haven't worn that jacket for a long time
how have you been?
Are you a black woman HCSC ? I have a certain fantasy that needs to be acted out, if you you are willing that is... :aroused:
No I am not black
my avatar is a true picture of me
but I am interested in your fantasy :uh-huh:
how have you been?
meh, same old. Car is all good at the moment which is kind of novel.
Did you finally sort out that boost leak on your 33??? You should really stop being weak and wind up the boost one of these days.
And you should really throw out those hideous chromies. Man I hate chrome.
yes I did it turned out to be a cracked manifold :P
I have since sold it and moved on to a R34 GTT with "Hello Kitty" stenciled on the bonnet, much nicer ride. There is a picture on boostbabes.com
and chromies are gone ... now I have some really cute deep dish polished rims
well I am hanging to go cruising again
especially with some guys, all the girls on boostbabes are too bitchy for me
they keep think I am trying to steal their b/f's
anybody up for a cruise?
haha
Jason don't you oh dear me, you and I have hung out many a time.
to everyone else reading back, please don't take offence to my warped sense of humour as I was just playing along and probably in retrospect went quite a bit too far.
I do have a dirty sense of humour and it was all just a laugh, but I realise now that I know quite a few of you on this site through other forums and car clubs.
so please forgive me, and don't forget some of you said some nasty things about me in this thread and I took it all as a joke as should you
Yeah, you do have a bit of an over the top sense of humor but it doesn't really translate that well on teh forums.
But I've found you to be a genuine person in the flesh for all the skeptics out there. (no pun intended)
you are probably right
gets me in trouble so many times :P
but I do like to play :(
:bananaman
oops there I go again
but seriously guys if any of you want to go on a cruise with me please PM
I live on the Gold Coast but do drive wide and far
(damn now I sound desperate)
nothing really
I was just using the name because the name of the thread is "looking for Hardcorskyline girl"
plus John I have been crusing with you before, even though you might not recall :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
