Just buy a proper dump pipe, get a split type if you really must, BATMBL has quite a few on offer here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=15558
costwise i don't really want to spend another 200 bucks plus for an extra piece of metal when I can use the gas axe, welder and a bit of pipe for about 50 bucks.
also i reckon that if i plum it close to the cat (as far away from the turbo, this will give better turbo efficiency because there is less turbulence. Thats the idea of the screamer isn't it?
what you guys reckon?
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1308991
The concept of screamer is when the wastegate dumps the excess exhaust gases to atmosphere. This is why it is called a screamer pipe.
It is recommended to plump back as far away from the turbo as possibble. This will reduce turbulence. For legal reasons this must be before the Cat converter.
Hope this helps
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1309013
run the screamer pipe through a 2inch cat or something mountedunder the car.
this way the exhaust is let off through a cat (not illegal)
then go to your local exhaust shop (EPA approved or whatever) and get a db test done.
when they rev it to 4xxx RPM, the wastegate wont open, making it legal noise at the required RPM.
its only loud under full noise.
Think about it. :cheers:
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1309942
Think about it. :P
Hey this is a clever idea :cheers:
I agree, this would work as you really only need a cat on the screamer pipe for legal reason's but mufflers and such are for noise reduction. The wastegate will not open at 4000rpm with no load so this will pass a db test.
You get the best of both world here, legal and a screameeeerrrr :wassup:
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1310191
However, even though you pass the noise test you may not be legal still unless you adhere to the standards regarding how far back and where you are allowed to vent exhaust gases. In the ACT i am prett sure you are *only* allowed to vent exhaust gasses out behind the rear bumper and are not allowed to vent at an angle. Just something to think about.
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1310298
not really, see thats extra piping, which in turn is extra weight.
when you could simply plumb it in just before your normals CAT
and you have no issues what so ever, and you save piping/weight and space
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1310392
In Vic I belive it's something along the lines of:
Behind the last openable window and on the drivers side
https://www.sau.com.au/forums/topic/70955-screamer-pipes/#findComment-1310410
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
