Hey guys,
The rims are r32 gts-t type-m's (pretty sure that is wat they are called) that came off my rx7. They are in pretty ordinary condition (good for drifting??) but come with 1 month old tyres which cost me 600 bucks (have receipts)
The specs are...
16 " 6.5 JJ (6.5 inch wide) +40 offset, 5x114.3 PCD
Tyres are Firenza's 205/55WR16 91W ST03 on the front and 225/50VR16 92V ST03 on the rear.
**price change ** 300 bucks for everything
*edit* new pictures added
Edited by brian earl spoolup
https://www.sau.com.au/forums/topic/71037-fs-rims-r32-gts-t-type-ms/
at the moment i can offer u 100 cause thas all i got at the moment but i think u want more..... will get bak 2 u if i can get cash
hey mate, yea 100 is a bit low. If u can get more together, get back to me.
Cheers
  • 6 months later...
how about 150, live in syd, meet you half way at  long jetty
sorry mate, thats way to low.
If you can organise frieght to Melbourne then count me in. I need new drift rims with some tred.
PM me.
Greg
If you can give me sum pointers to who i should call for frieght prices it would help
Cheers
Cheers
www.busfreight.com.au
They should be the cheapest.
Greg
  • 5 weeks later...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
