Currently using REPSOL COMPETIZIONE ELITE but will be switching to MOTUL V300 CHRONO from now on.
Someone i know blew there oil filter out and ran with no oil from the gabba to tingalpa and was up it quite a bit a lot of the way as didn't realize had no oil left in motor.
The workshop pulled the motor down and said why did you want us to look at it and didn't believe he had run without oil as was perfect. Not a thing wrong !!!
He was using MOTUL V300 CHRONO when this happened.
Is enough to convince me that this oil is the stuff to get.
Jamie
this 'gal' uses (and recommends) Target Premium Brand...costs $7.99 for 8 litres...........stuff paying $25-$30 like the rest of you guys (and gals)!!!
By the way, the grocery guy at Target rekons 20-50w is pretty good!
mmmm.................
Seriously.........Like everything in life you get what you pay for....just get the first number right!
i done much searching on this for my first oil change in the skyline, and the impression i got was Motul 4100 10w-40 was where its at.
so.. i went out and bought like four litres for $50 from autobarn.. you guys had better be right :)
(no no.. i wasnt threatening.. honest!)
shaun.
so.. i went out and bought like four litres for $50 from autobarn.. you guys had better be right ;)
shaun.
Shaun,
your baby will be just fine!!
I love this stuff, and so do a lot of other people.
Never actually heard a bad word about it!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
