Hi everyone, well, the green machine is up for sale. (yes really...) So here goes:
1995 R33 GTST
nearly 130,000 km
Custom paint (acid rush base)
Hybrid GT34R high flow turbo
High Flow fuel pump
high flow pump-in tank
custom dump pipe
Hybrid FMIC
Hybrid dual stage boost controller
Apexi SAFC II
3" cat back exhaust
Apexi pod filter
lowered/suspension
Falken tyres (2 yrs with still good tread)
17" Pilot Racing 'tracer' mags in shadow chrome
dark window tint
upgrade speakers (pioneer and fusion)
new battery
have most receipts and dyno test graphs. Runs 214 kw@rw on low boost. Approx 230kw@rw on high boost. (was going to get dyno tuned from Jakes performance, but wont now due to sale)
This is a very quick car, she stands out, and is a real head turner.
Reason for sale: it's just time to move on, have made an offer on another car so am motivated to sell. For more detailed info on the condition of the motor/interior/paint etc please PM me and either Stu or I will get in contact.
Asking price is $29,500 ONO.
A lot of people on the ACT forum know what my girl looks like, and I will put this on the for sale thread in the forum and on the net. This is just in case you know anyone who is looking for a R33 gtst.
regards,
Kate.
**** Having technical probs with carpoint.....contact nbr is 0409 035 706*******
https://www.sau.com.au/forums/topic/71364-for-sale/
  • 3 weeks later...
Thanks for your support, and yes Patrick it is very sad, but she no longer is in my garage, as of today..couldnt watch Stu drive her away, there was a tear in my eye!! (how pathetic) Now in her place is a gold twin turbo soarer (and auto at that!!!) I know just about all of you will say a soarer???? WTF???? Anyway...but she IS a good looking car, and there are some advantages and there are some plans for her later on down the track, but the hard work has already been done. I guess that means I am not skylinegal anymore....how sad....
https://www.sau.com.au/forums/topic/71364-for-sale/#findComment-1364265
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
