  • Replies 51
Originally posted by XrSiSt
Good to see the beast is almost ready to make it debut....
URINE and u should come 2nite.. just have a chat and the
famous donnie steaks....
BAHAHAHAHAHAHAHAHHAHAHAH URINE
BAHHAHAHAHAHAHAHAHAHAHAHA
omfg i havent laughed soooo much since a couple of mins ago....
bahhaahahhhaahhahahahhhahahahahahahhahahaha
pauls owns URINE !!!
hahahahahahahhahahahahahahahah omfg omfg......
ROFLMAO
it hink eirc is still tipsy from sat night... hahahahahahahah
https://www.sau.com.au/forums/topic/7157-finally/#findComment-105355
So I picked up my filthy, filthy car yesterday afternoon & after an embarrassing flat battery related incident on Epping Rd during peak hour I got it home.......
Now all I have to do is get it serviced, registered and give it a hardcore polish.
The shocks in this thing are sooooo hard. I can feel/hear every single little bump in the road. Hopefully I'll be able to get them loosened......
https://www.sau.com.au/forums/topic/7157-finally/#findComment-105962
Originally posted by nissaner
cool...congratulations dave.... :P
can't wait... GTR vs GTiR !!!
will see u around feburary (i am in korea atm)
Thanks John.
By Feb I'll have all my goodies bolted on to it so I may be able to give you a run for your money.......
Have a sweet time in Korea. I'm hopefully going to be over in Seoul sometime this year to visit one of my mates who lives there......
https://www.sau.com.au/forums/topic/7157-finally/#findComment-105983
6k then dump hahahahahahahaha man dave if you even try and make it soft i will gank you big time. Hard=Hardcore ok silly boy.
Oh and full cage yes dave :P
So its got aftermarket sus i take it hmmmmmmmmm and you would think they could ****ing clean it for you god dam them to hell
:headshot:
https://www.sau.com.au/forums/topic/7157-finally/#findComment-106010
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
