I have the following items for sale. All parts are from an R32 GTR (RB26DETT) unless stated otherwise.
Brand New N1 Oil Pump - SOLD
Brand New N1 Water Pump - SOLD
R34 GTR Injectors - SOLD
R32 GTR Fuel Pump - $250
Complete head including stock cams - Was 1250, Now $1000
Oil pump - SOLD
Water pump - $50
R34 GTR Sump with no diff - $200
2 x Exhaust manifolds - $200
2 x Stock dump pipes - $50
Alternator - $80
6 x R34 GTR coil packs and wiring harness - $200 (built in igniters)
6 x Std Coil packs - $200
2 x Cam covers - $200
Turbo oil & water lines - make an offer
Block - SOLD
R33 GTR Crank - SOLD
6 x Rods - SOLD
Crank pulley - SOLD
Intake plenum - SOLD
6 x Throttle bodies - SOLD
Adapter between throttles and head - Make an offer
Fuel rail and pressure regulator - SOLD
2 x RSR Stainless steel exhaust manifolds - SOLD
2 x Stock turbos - SOLD
2 x Stock AFM’s - SOLD
Trust clear cam gear cover - SOLD
Front brake callipers (4 pot) and lines - SOLD
R-SEC chipped ECU - SOLD
All prices are negotiable
All parts are located in Townsville, QLD, and can be sent anywhere at the expense of the buyer.
Contact me on 0401 136 794 or [email protected]
Cheers,
Gary.
https://www.sau.com.au/forums/topic/71673-r32-gtr-parts-for-sale/
  • Replies 53
Hi Gary;
is there any difference between R34 and R32 GTR manifolds?
Regards
The R34 ones are much newer (19,000 km) and obviously in better condition. As for the design I'll have a proper look tonight and let you know.
Hi Gary;
Regards
I had a look and although they have different numbers cast on them, they appear to be exactly the same. So I'll make the price the same for both.
Would the R34 coil packs fit into a R32 RB26 ?
The R34 coil packs will definately fit but they have built in igniters. This means that you need to modify the R32 wiring to bypass the igniter module and go straight to the coils.
I will supply the harness for the coils also.
I received a lot of responses and hopefully I have replied to everyone. Please let me know if I have missed anyone.
I have just found out that the crank is an R33 GTR crank, as it has the full length connection to the oil pump. Does anyone know how to tell if the rest of the motor was an R33? Any other differences?
I also have the wiring harness to go with the R34 coils.
Hey Mike,
Unfortunately one of my turbos died and the bits of ceramic went back up into the motor. It lost compression on 5 cylinders. I have an R34 motor in the garage waiting to go in.
Are you still in Townsville? We still have to catch up!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
