just wanna ask...is it ok if i put some gauges on dashboard,a friend of mine said i can get defected
Depends if its interrupting your field of view.
There are certain places you can put them without causing too much trouble, I think.
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322769
welcome :)
More skylines the better, more vic people... well... its perfect.
Dont forget to check out our club thread.
Its going strong with over 120 members thus far.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=60590
also come to AutoSalon on the weekend :)
see my sig for more details
-ash
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322904
hey howz it going? What sort of skyline did you get?
hi there...just put new rear tyres yesterday..ive changed the steering wheel and shiftknob and put a bodykit a week ago...planning to put some gauges and many more LOL...it's GTS-T mate whats yours??
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322922
BiAsA: Have a look at my car at Autosalon. Golgo - purple GTR. Roof racks. Rad.
Has 2x Apex'i LCDs on the dash. Never been troubled for them - except one is an EBC and they're naughty. Not in direct field of view - but are ergonomically tip-top.
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322950
:D
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1324375
Quote:
Originally Posted by VLS_BACK
buy a VL
i dont get it..whats that???
An inferior species normally found in the Holden neck of the woods!
Yes that is coming from a Ford fan so dont take it personally VLS_BACK!
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1324429
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
