just wanna ask...is it ok if i put some gauges on dashboard,a friend of mine said i can get defected
Depends if its interrupting your field of view.
There are certain places you can put them without causing too much trouble, I think.
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322769
welcome :)
More skylines the better, more vic people... well... its perfect.
Dont forget to check out our club thread.
Its going strong with over 120 members thus far.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=60590
also come to AutoSalon on the weekend :)
see my sig for more details
-ash
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322904
hey howz it going? What sort of skyline did you get?
hi there...just put new rear tyres yesterday..ive changed the steering wheel and shiftknob and put a bodykit a week ago...planning to put some gauges and many more LOL...it's GTS-T mate whats yours??
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322922
BiAsA: Have a look at my car at Autosalon. Golgo - purple GTR. Roof racks. Rad.
Has 2x Apex'i LCDs on the dash. Never been troubled for them - except one is an EBC and they're naughty. Not in direct field of view - but are ergonomically tip-top.
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1322950
:D
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1324375
Quote:
Originally Posted by VLS_BACK
buy a VL
i dont get it..whats that???
An inferior species normally found in the Holden neck of the woods!
Yes that is coming from a Ford fan so dont take it personally VLS_BACK!
https://www.sau.com.au/forums/topic/71721-hi/#findComment-1324429
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
