As above. Its hard to explain what its really doing, i can really on tell my story and what ive tryed and soforth, so see how it goes..
ITs started with comming home after a long day at work..... Spent half a hour got changed and went out. Now i drove the skyline home. and it was running sweet as. Now after hoping back in. No go. it seemed it didnt want to even bite on cranking. It was getting spark and getting fuel. (by the looks of it). After 30mins of waiting. she seem'd to of went. GREAT!
40 mintues later of driving. She started to break down. Missing. Coughing. It started with a bit of a miss/stumble on boost. (6psi atm) backing off the throttle and back on cured it. Then it became progressivly worse. Light throttle Intoduced large amounts of missing. And over the cause of 3km it wouldnt of even idle.
TRying to get up a hill was entertaining.
SO i was sitting on the side of the road in pitch back looking around my engine bay with my little pen with a light on the back of it. And noticed my water temp sensor plug had one of the terminals off, inside the plug hosing. Here's me thinking "Yippie" She will go now. Which i was right. Sort of. Still missed only running on 5 cylinders. This got me able to drop this off at a Friends aunty's place so i can come back for it. and so she was safe.
Next day........... **ding**
Had a look. By the looks on every plug. Overfuling. they were all foued and coated in fuel. Cleening them made no improvement in running. as well not it wont even idle.
Ive replaced. "Water temp sensor", AFM, FPR, dizzy cap. Check fuel pump. and line blockages. Spark is strong and timing is fine. The top of number 5 injector is now leaking, yet again i had only just replaced it.
Its now the point of. no matter what i do the plugs foul. Cleen them, bang foul.
Any idea's ?
Its now at the point of. I replaced the FPR 2 nights ago. And the fuel lines seemed to of primed alot better than the other Fpr did. But now my Fuel pump is pulsating. Its getting a perminant 12v sorce from the battery and is Switched throuh a Relay thats trigured off the car alarm.
https://www.sau.com.au/forums/topic/72154-l20et-overfuling-badly/
Sound like what my FJ was doing when I( first got it. Turns out (after much swearing and setting up a compressor to push 10psi into the cooler pipes) that a hose (might have been positive pressure, I guess it couldnt have been vacuum because the engine wasnt running when I found it) under the inlet manifold had come off. It was just in the right spot that you couldnt see it from underneath or above the car and you couldnt really hear where the noise was coming from, but once I put it back on it was fine
It would definitely have been overfuelling with the broken water temp wire - the ECU would think the engine was cold and it delivers much more fuel to a cold engine.
I suspect the excess fuel has destroyed the plugs. I think new plugs should solve all your problems (but I've been known to be wrong before!).
Well, you guys were thinking along the same lines as me, And i replaced all my leads and plugs, with standard bp5es. Its been running better than before i can now rev to 7k, "not much tho" when i used to run out of spark at 5k. This is only on 6psi 3rd gear has a hell of alot of pull.
Heres a good one, Why does 1st and 2nd have no pull, evenknowing its at 6psi, but 3rd gear just honks compared to 1st and 2nd
not that im aware of....my NA C210 was doing exactly that, (l24e) and it turned out to be the afm connection....maybe you have a dodge wire in the loom? check that out...there may be no prob with the hardware at all.
ah, if your relating to my Ovefuling problem, luckly thats sorted. I noted when it was doing it, AFM. and repalced that. which was still doing the same thing. But lucky it took me a while but found out all the leads had broken down. wouclnt show any problems without a load on them
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
