i drove my car up to calder from geelong basically straight to the start line ran an 11.5 @ 120mph my rear diff caseing smashed in to the chassis and shattered it in to bout 10 pieces oiled the track down and took them bout 45 mins to re prep the track, sorry guys. i had to leave my car up there the night too.
ha ha she loves helping me do stuff on my car she ends up getting dirtier than i get.
Todd's got his Mrs trained REAL well!!
She chamois' his ride for him @ the carwash - my GF would never dream of it!
(I was the guy next to you with the black 34 in Geelong a month or two ago).
;0)
Saw your run, was moving along quite nicely :(
Next time, don't smash your diff, i hate waiting for them to clean the track, happened about 4 times that night
yeah sorry dude i felt like the biggest asshole but at least i wasnt the only one who oiled the track down, other people took the spotlight for me. i need to find out why the rear diff caseing hit the chassis, i thought it was just the bumb stops but i was wrong.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
