Hi All
I just fitted a ARC FMIC Kit yesterday and the power feels more smoother but no as great...the kit was second hand, do you think that there could be a hole in the cooler or hosing, or do you think its just my imagination...any help would be great...and yes ive double checked the clamps and they are super tight....cheers
https://www.sau.com.au/forums/topic/72288-intercooler-question/
Hi All
I've had a small hole in my cooler before. You definitely know when you have a hole in that you can definitely hear it even off boost.
not vacumm but boost seems a little low (still at stock) but feels not a hard to kick in...i didnt know if this happened when fitting a fmic or not
Whats your vacuum at idle? should be around -500 ( reading of the PFC hand controller on mine)
Umm I am definitely no expert... but it just sounds like the bit of extra lag you get from fitting a FMIC and all that piping compared to the stockie???? Normal I thought - hence why u normally combine the FMIC with mods like a full turbo back 3" exhaust and a bit of extra boost etc to balance out the lag... the FMIC istself doesnt do much for performance - but creates a cooler environment to allow you to fit more mods and up the boost with less risk
Personally I wouldnt do a FMIC if you werent modding up - but then again thats just base on other reading in here - so i could have it completely wrong :rolleyes:
i will check the vacumm next time i start up...brazen cheers , but i have a 3inch system
Yeah - but whatever mods you have - at the point you install a FMIC you will get an increase in lag over what u had before the FMIC... did u have a FMIC before and just swapped to a Blitz system - or go from stock sidemount to FMIC?
Yup - thats all it is - you've introduced a bit more lag with the extra length of intercooler pipe - so it'll feel a bit more sluggish - although your peak performance probably hasnt dropped - just changed your curve.
The FMIC just now will allow you to do a few more adventurous things to up your power and push it power back down the curve a bit - whereas pushing a bit more with the stock cooler would start getting risky further down the track... talk to your tuner... but the FMIC and maybe a couple of extra bits and pieces should now let you up your boost if you so wish or do more hardware mods. It wont take much now to get that lag out of the way and make the car FEEL fast again :(
if the cars stalling, from my experience, the fmic should have nothing to do with this saga..
perhaps, check with your tuner about these few things..
- b.o.v could be leaking,
- fuel pump maybe earthing
- if its a series 1, rb25det, check you coil packs & the ignitor pack above the #6 coil pack
- crank angle sensor maybe ****ed, & might need replacing
* my car did this, i though the b.o.v maybe leaking, but that wouldnt cause your stall
- my cars crank angle sensor was not sending the right signal, & the ignitor pack was ****ed as well, ive replaced both c.a.s & the ignitor pack ( as we speak its in shop) & the mech said thats my problem, maybe yours too...these are just a thought...
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
