May Monthly Dinner - 26/5/2005 - The Great Northern - Pacific Hwy Chatswood
i may have to pass :(  i've double booked myself! :(  don't miss me too much richie! :)
I am now afflicted with a sadness that words cannot describe. :(
perhaps you will grace us with your presence at a future dinner.
  • Replies 222
Cool.. looks like I might finally be able to attend one of these dinners!! Looking forward to meeting you all.
A NewTattoo.. where abouts in Artarmon are you? I'm in Artarmon too :)
Oh just near the station~~
hey mayb i hav seen ur car somewhere around here before~~~
we should go together~~!!just in case if no one is there~~
my grandpa ghave  me this frozen chinese sweet & sour pork thing on the weekend
microwaved it last night
i've had nasty gas since this morning!!
you sexy beast.
Joy, do you park your car on Hampden road? If so I've seen it there quite a few times whilst driving past in the GTR. :)
Yeah~~
must be mine~~
that's why i wanna move~~i only got street parking now~~
but i can see it though my window.....
is ur car wine red??
so on Thursday night , how can i tell where do u guys sit?because i dont know anybody yet......
wait a minute ...i m confused~~~
is it behind the bottle shop??or cross the road??
Yeah~~
must be mine~~
nope, gun metal grey GTR. this one:
as to finding us. hmm, well I'm about 6feet tall 300 pounds and white (which probably describes half the people at the northern).
I'm sure you'll find us, just keep asking people if they are from SAU until someone says yes :)
Joy, look for the fat guy in the VB singlet and stubbies, thats mmmgtir.
yep, that's me, I will be standing next to the rapantly gay guy wearing tight leather pants and a leopard skin t-shirt, that's Tosh.
:uh-huh:
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
