Can someone please photoshop this picture of my car
http://gtr.ferni.net/photos/09%20-%20calde...-2-05/Ferni.JPG
and put this Series 3 lower lip on it:
http://www.nismo.com.au/pricelists/General...ries3gtrbar.jpg
with the lip in the same colour as the front bar, and a 2nd pic with the lip in black?
Thanks :P
https://www.sau.com.au/forums/topic/72383-photoshop-my-car-please/
thanks :( better than i could do. Can still see the old front lip underneath tho... but it has made me realise that i'll need to paint the inside bit of the front bar (around the intercooler) black or purple as well :(
nismo_au: thanks :D
Al: yep took me a second to reconize you - sun was reflecting off your window. At first i just thought it was someone giving me the thumbs up about my car which is normal, but then looked again and saw it was you hehe, was taking my mate to subaru to check up on his cars new engine.
Thanks cogs! you guys impresse me how you do that - i can do simple stuff in photoshop, but can't do stuff like that for the life of me ;)
What about putting this lower lip on :
http://www.nismo.com.au/pricelists/General...gtrlowerlip.jpg
Which one do you think will look better?
Hey dude. I reckon the series 3 lip looks better.
Here's my 5 min photoshop job of the nismo lower lip
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
