Wheels and tyres for a R32 GTS-t
By RB25inside · Posted
Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
