Neo_R34's has been sent out today. started on 8 more, about 10% done atm, ill keep 2nd post updated on progress. anyone else interested let me know (here or pm) and ill add you to list.
  • Replies 102
ive almost finished the next 8. 7 of them have been tested, and just require the consult connector to be added, and place in box (with lid drilled for led).
webber, bless_you and maximumrpm, ive sent u all a pm.
by the way, this will be the last lot for a while (uni assignments/exams coming up) - at least till july. then ill also be looking into making custom pcb so that i can make a kit for others to put together themselves, to save me time (and theyd cost less obviously for u to put together yourself)
they take too long for me to do them all, especially when i have more exciting things to move on to (including pocketpc consult software).
nate's is completed and sent off today.
3 more almost completed (10mins to finish each off, just add consult connector) and 4 more need box drilled + connector. updated second post.
  • 3 weeks later...
currently pretty hard cause the only instructions/layout id have for it on an excel spreadsheet :) (ive attached a pic of the spreadsheet just if u want to see for urself what im working with atm. the pcb has two lines on the left, with 18 rows across of 4 holes each (seperated by the width of the ICs).
custom pcb would definitely need much easier, would just be much "cleaner"/easier to put together...but id still need to design that and find out how much itd cost
id imagine the kit would hopefully be around the 40$ region, depends on the custom pcb and how confident id be if i got x custom pcbs made that theyd all be used.
please pm me when you are ready to make some more.. put me down for one
uve got 4 more which are close to completion...might be able to finish them on wed. i can put u next on the list?
unless u mean u cant afford it now but in the future?
You keen to send to NZ? i'm very interested, and i know some others who may be interested.
are you aware of the guy making them in nz? might be easier for you to get one from him?
http://www.blazt.biz/300/interface/index.html
edit: box 1 and 3 sold
i also have 3 imperfect/test boxes which are available if anyone wants one for cheaper. note i cant guarantee all of them will dump entire rom (or other extended operations, but less chance of that) without hanging. im pretty sure the first two can (but havent been able to get box3 to yet), but cant actually remember so assume it cant.
box 1: 3 leds (power, transmit/receive), larger box, short cable to proper consult plug (~50cm) and serial plug on box. some serial cables may not fully insert (but still connect...my normal serial cable is fine, but the usb-serial converter, which is fatter, doesnt go in all the way due to other connector on side of it) $35
box 2: no leds (not even power), 50cm to serial plug, 170cm to wires for consult port - no consult plug. need to watch connectors dont break. $15
box 3: one of the boxes i was making in this thread, perhaps due to imperfect component somewhere (dont have time to check/replace everything), i havent been able to dump full rom with it. 50/170cm cable lengths or there abouts, with consult plug. $35
heres the first two:
box2 youd need to be able to hook it up to consult port yourself. this is around or less than cost of components to make them (consult plug itself is half the cost), with the only real downside being possible hanging with long operations (typically rom dumping...potentially normal data logging/viewing/gauges etc could hang, but not much chance of it). i have no real need for them, so thought someone who wants one for cheap that isnt interested in rom dumping might be interested. pickup preferred so u can see it working, but given they are so cheap, cant really afford to provide any assisstance with them.
Peter
  • 3 weeks later...
Update:
Sold two of the test interfaces, only have the 2nd with above, the one without consult plug. Turned out the box3 dumped a full rom without problems to the guy who bought it.
Have completed 2 of the last 3 interfaces, and sent pms to the first two on the waiting list. Once these last 3 have sold ill look into getting custom pcb done to be able to make a kit for around the $40-45 mark that u put together yourself.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
