  • Replies 116
Hey where abouts in melbourne r u? Do u still have the inside air conditioner air vents if so how much will u sell them for becos i need 2 put them in my car so it can pass a road worthy can u please call me on 0413442008 catherine after 4.40pm thanks
I'm after the abs unit with all brake lines, rear grab handles in the interior, rear seat belts, rear winscreen wiper, and the plastic that goes under the front bar and front of the gaurds. Could you pm me a price with your mob no since I lost your home no.
QUOTE (>GoDziLLa<)
Decided to seperate parts from smashed GTR
HKS twin Airpods - $150SOLD
Nismo strut brace - $200SOLD
HKS oil cooler+Oil filter relocation kit - $550SOLD
Volk Racing three spoke 17*9.5 Wheels - $800SOLD
3 inch front pipeSOLD
almost brand new highflow cat - $200
bonnet and latch - $450
bootlid and spoiler - $250
right front guard - $200
left front guard little damage right on edge - $100
front bar + lip - $200  SOLD
front bar reinforcement - $200 SOLD
headlights - $250 each
Set of genuine mats $80
front blinkers $100 - eachSOLD
rear taillights and surrounds set - $250
KYB Ride Adjustable street use suspension - $800
front brake calipers with pads - $400
Rear calipers with pads - $200
HKS old style boost controller - $130SOLD
Essential Jap tuned ECU, 8200 limiter no speedcut - $180
rear diff - $600
Gearbox - $900
Engine and loom RB26DETT 150,000kms brand new iridium spark plugs
and O.S Giken cam gears(not sure though) good condition  $4000
O.S Giken Twin plate clutch good condition never slipped $1200
Brand new 2 rear brake disc rotors $300
rear driveshafts $300
centre console piece with the 3 gauges $80
driver side door complete $350
Fuel pump $200 SOLD
Windscreen(with built in aerial) $300
Rear window $200
All prices negotiable,
can do good deal if someone buys engine,gearbox and clutch at same time
Please ask if you want pics of certain parts
Hi, Do you still have bonnet and bootlid? If so, what price will you take for both?
Thanks
26 Motorsport
Hi,
Also after your guards too, condition not an issue, for a race car. Can bring around cash and pick up from you when you're available.
Call me 0407 322110
26Motorsport
I'm intrested to bye these items.
Contact me on 0405595035.
