haha sometimes the pics don't help do they? its a little metal cylinder with a yellow plug on the end, 90o back from the oil filter
1/ Remove the plug (under a dust cover) on the back
2/ Unscrew the sender anticlockwise, off it comes :rofl:
Should it come off pretty easy. I did find it but was having trouble removing - I even borrowed a tool that latches onto the back of it (i.e onto the hexagonal piece on the back) and you connect a 3/8" bar to it. Maybe if I remove the plug it may work better.
I've decided to just do my timing belt first as I don't think the oil pressure is a problem. I wanted to check it in case it was the oil pump - in which case doing the timing belt I am almost at the pump.
Meanwhile since I've played with it a bit I couldn't get it to read much beow the 2 mark on the stock gauge..
Thanks Duncan
You can use a 14mm spanner on the closest side to the block. Easier to get at from underneath and behind the R/F wheel. That is of course if you can get underneath.
On the issue of your oil pump....if you own a skyline, which I assume you do, you cannot remove the oil pump without removing the sump. Do not even attempt to as you will wreck the sump trying and you won't be able to re-seal the pump when you figure out you have gone too far. Also, you probably won't be able to get the timing belt lower gear off for reasons I won't get into, which means that removing the pump will be almost certainly near impossible without either breaking the gear or the pump. If you have any queries PM me and I will be happy to point you in the right direction.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
