Have been thinking of buying a Nismo 320km dash for my R33 GTSt.
Only problem is as it's an auto, will this affect the workings of the dash etc? apart from the obvious of losing the PRND21 dash display?
Any info on this would be much apprectiated.
https://www.sau.com.au/forums/topic/72918-nismo-320km-dash-r33-suit-auto/
  • 3 weeks later...
Hey Guys,
I've just ordered one from Nengun, just wondering what would the top speed be if I installed POWER FC to override 180Km/h Cut off?
What's the highest you guys have gone in urs?
And did a normal autoelectrician install it or did u do it urselves?
Cheers
Iceduck
i know for a fact a speedo from an automatic r33 will read very low when used in the dash of a manual r33. i believe this is due to a difference in the speedo sender in manuals/autos.
so if you install a speedo that is meant for a manual i am quite sure it will read very high.
it's not the diff ratio. it's difference in the speedo sender in manuals/autos in the gearbox
so if you get an 320km speedo from a manual and put in ya auto it'll only read about half of the speed of what you are actually doing. eg: if you are going 60k it will only read about 30k or less
apexir33 is spot on, as far as i have found the difference is due to the speedo sender. and it will read about half or double (depending on which mismatch it is)
Hm, when I'm doing 100 on my speedo, it is actually 91 according to the speed check LCD on Princes Hwy from Geelong to Melbourne. Mine is converted auto with stock manual gearbox and retaining the auto's 4.3 diff. Based on your argument, it's not half, it's only about 5%. I think a factory manual R33 with 4.11 when cruising along at 100, it will show around 96 or 97 on the same Geelong speed check display.
Sorry, I missed this.. if the speed sender is in the gearbox, then yes, you're right then... because my gearbox is now manual, the manual speed sender should be in the gearbox when I converted it, and I have a manual, 300kph nismo speedo. It was still the same case with stock manual speedo, 5% less, which is contributed to the different diff ratio.
I have a 320KMPH nismo speedo on my R32 GTR 2 speed manual and an apexi multichecker.
when I'm going 120 on the speedo the multichecker reads only 111 ish. but the speedo feels more right. Is there a way to check which one is more correct?
Also I read that a stock R32 GTR can get up to 250kmph max, is this a gearing issue? I've been over 200 and it's not that close to the redline.
When changing wheel sizes we know it can put the speedo a bit out of wack & I've heard this can be corrected by either changing the sizes of the trans gear or driven/ speedo gear to which the speedo cable is attached to. This will change the rate the speed is read; there were ratios to work out which size gears to use but that part went over my head. So, not sure if similar concept could be applied here.
Anyways, I thought an auto electrician should be able to recalibrate the manual speedo cluster to fit an auto to give correct reading.
Gearing plays a part, then traction loss, and as well as aerodynamic drag... All this making achieving 250 possible top speed seems forever, best done on a very long straight like the Motor's top speed test in Avalon Airport or car testing oval circuit with cambered corner? An R34 GTR with 6 speed makes it possible to achieve more 250km/h Motor magazine I think had a modified R33 GTR achieving close to 300km/h
Thanks for the Info. So it is actually not a redline redline limit that dictates the top speed.
There for if the environment was right, eg, very straight road/track and you decided to test your top speed, it won't hurt your engine as much as using a car for drag.?
Well provided you didn't slam your gears to get there as fast as possible (like in drag racing) I suppose it will be more gentle on your engine and gearbox. However prolonged high revs to achive that top speed (e.g. 6000rpm in 5th) may possibly do some bad things to your engine/tranny, especially if the car is not in top condition.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
