Am currently getting some pretty high under bonnet temperatures, due to the custom dump pipe, as I cannot fit the factory heat shielding.
Does anybody have any idea whether heat wrapping could have any adverse effect on the dump pipe as I have heard that it can change the qualities of the steel and make it brittle?
Also other than heat wrapping does anybody know of an efficient way of Keeping the underbonnet temps down?
Any advice would be greatly appreciated
Cheers
Steve
https://www.sau.com.au/forums/topic/7297-heat-wrappingheat-shielding/
i have had good results with that cool-it thermo wrap stuff, not on the skyline, but on my old turbo gti. the heat difference was excellent (judging by touching the exhaust) it went from wholly fcuk (hot) to hmm nice (warm)
not sure of peformance advantages though
hope this helps
Steve,
I believe that a place in Perth can now do ceramic coating, which is apparently better than heat wrapping, plus it looks much neater. If your interested I can try and find out who is doing it and the rough cost for you. It is what I will be doing to my new exhaust manifold.
See'ya:burnout:
Thanks for the replies
Broken,
Sounds good, where is it available, and do you have any idea of cost, and is it easy to put on - sorry about all the questions
GTS-t VSPEC,
that would be good thanks. I had a look into it when I got the dump done, but it was only available via adelaide, and the cost was nearly as much as the dump, thanks to shipping.
steve, the stuff that i used was called cool-it - made by thermo-tec. any car shop should have it, from memory it cost about $100
it is a fibregalss material, that you wrap around, and then spray with a sealer. make sure that your wear gloves, cause fibreglass fibre splinters in your hands is a real b i t c h .
One thing that thermal wrapping/HPC does is to keep the heat in the exhaust. This means that the air will flow faster and help spool up the turbine quicker. That said, having higher exhaust temperatures can affect oxygen sensors and catalytic converters. You may want to investigate high temp O2 sensors.
For those running full race cats, heat shouldn't be an issue, but those who have "highflow" or semi-race cats, realise that they only take so much abuse.
As far as destroying exhaust, I can't see that happening, unless you already have issues with it. It may dis-colour your Stainless steel tip quicker?
In the end I think Thermo wrapping is a good thing, you just need to be aware of what it does and the side effects.
Feel free for anyone to add or correct me.
Cheers,
Tim
Wrapping the exhaust is fine ,it may shorten the life of the exhaust but its still going to last 5 or 6 years also get some kind of heatshield back on as it mainly shields the turbo which gets pretty hot anyway.
My blocked air conditioner drain turned out to be the drain tube where it enters the engine bay had got so hot it melted the tube into a blob so all the condensation(and theres lots of it ) was comming into the car through the a/c vents
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
