Happy bday Lozza!!!
I'm sure with all the gym work Paul has been doing he will give you a strip show tonight!
It wasn;t so long ago that we were all getting drunk at Steves together!! and you gals were getting kicked out of the casino if memory serves me correct!
awwww shucks guys and girls!! :grouphug:
Yes im old today - as paul pointed out this morning - i know longer get payrises on my birthday *sob*
Steve's feels like just yesterday!! My being kicked out of casino days seem long behind me :D Now where did i put my knitting needles :)
But honestly THANKS!!
Paul when i get home tonight theres going to be a 350Z in the garage with a big bow around it right????
sure.... if only there was a toyworld nearby.... decisions decisons decisions... tonka or matchbox.. mmmm :D
Happy Birthday Lauren. Hope you have a good one
my old boss is now dealer princpal of a Nissan dealership - said i could test drive a 350Z whenever i wanted ..... and my current boss said i could go early today if i wanted - so ive been kinda tossing up whether to go drive one today ..... but one of two things will happen
- I'll fall in love and want one more .... if wanting one more is possible.
- Or i'll be terriblely disappointed and it will ruin the dream.
So ive decided to stay at work haha
Thanks kids :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
