my r32 seems to not want to idle below 2,000 rpm originally my throttle body would stick when the idle pin was screwed in( too lower the idle below 2,000 rpm) I have replaced the throttle body and it no longer sticks but still sits at 2,000 rpm. I have gone through idle adjustment procedure and the ecu section seems to do nothing on my car and the valve control only lowers it to 1,500 rpm or so. I then cleaned the valve as suggested by others this seemed to work for a little while(sat at 1,200 rpm) as the car warmed up it rose very slowly back up to 2,000 rpm. Please help ps my car was auto to start with but idled at 2,000rpm in park then too.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/
check this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=69151
seems like this is fairly common, mine does it aswell. im gona fix the air regulator soon
im pretty sure the air regulator is my problem cos if i take it out for a drive and it really warms up the idle eventually falls down to about 1000. I haven't fiddled with my screw yet but i will once i get to to start idleing around 1000 to get it down to 750'ish.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1344500
From memory, the resistance (ohms) between pins 1 & 2 (the top 2) should be 0 when the throttle is closed.
A quick check would be to remove the plug while the engine is running, and short the 2 pins on the loom side with a paperclip. If the revs suddenly drop, then you need to adjust the TPS.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1345737
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
