Just replaced mine (32 gts-t)
DBA slotted were quoted around $200 a disc... I was thinking this was going to be costly exercise but needed it done as my rotors were warped from when the car was imported.
I ended up with ventilated Brembo's for $65 each! (new). I replaced the front rotors only and put new brake pads on. Works a treat.
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1356783
thanks guys, this is what i was after, i bought a set of DBA slotted rotors for the hr30 about 18 months ago and they were 340 each, the first set they had made for a r30 skyline, i've now upgraded the fronts to r32 gts-t's 4 pots and rotors and was hoping that new rotors would be alot cheaper.
DBA will make a set of r32 rotors in the 4x114.3 for a bit more $$ wont they?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1356876
Is it hard to replace front rotors, and is there instructions online?
Thanks
al
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1364729
I put DBA rotors on the front and some protec cheapy's on the rear as I was unable to soruce DBA rear rotors for the R32 anywhere in Adelaide. :)
From memory the front DBA rotors varied in price massively.
Cheapest place to buy DBA rotors from In Adelaide are Motor Mates.
Where did you source yours from Pablo?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365047
ended up getting quotes, from autobarn for DBAs and glodal auto spares for RDA,
the fronts with DBA were 325 slotted and with RDA it was 283 for the slotted, the biggest difference was the rears for my hr30 were 269 for the DBAs' and 135 for the RDAs' both slotted
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365288
It seams the smaller houses will get these parts cheaper as they want you to ome back and use their services, so shop around. Perth Brakes Australia is one of the bigest suspension and brake places in WA and they wanted $2656 for each rotor. HA? So go see if there are garages that tune and race their cars as they will be more connected with manufacturers and sponsors at the same time.
Al
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365361
$65? what the? where from mate?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1378375
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
