I'll start by saying I know sfa about car audio so please excuse me if i ask stupid questions.
I have the following:
- jvc mp3 h/u
- mb quart splits
- signat 2 channel amp (2x60watt rms)
- pioneer 2 ways for rear fill (run off h/u)
- 10" mtx sub (will run 100 - 200 watts rms)
I need another amp to run my sub, my options are:
- buy another 2 channel and run two amps
- sell my current amp and buy a 4 channel
Will running two amps drain my battery of power so I won't be able to listen to my system for very long with the engine off? Will I need to upgrade the alternator or anything else?
Thanks for you help! :P
Cheers,
Greg
https://www.sau.com.au/forums/topic/7331-your-advice-wanted-please/
Running another amp = more power = more current drain. So in short, yes.
Depending on how good your charging system is you shouldn't need to upgrade your alternator. You might also want to consider investing in a capacitor - not essential, but will help "smooth" the current flow to the amps.
Why not purchase a 4 channel to run the speakers & bridge the sub of the 2 channel? By running fronts off an amp and rears off the head unit you will probably find that the rears won't have enough volume.
  • 3 weeks later...
to starr with...amps are designed to run when the car is running...ie. 14.something volts, not 12! so running it when the car is turned off isnt that good. but ive found if the amps arnt staining for power (not enough power for the speakers) it doesnt do much harm (well, noticably)
if you are only going to be running a set of splits and only 1 sub, i wouldnt worry about a capacitor, just upgrade your battery perhaps.
amp wise, a 4 channel amp would do the trick...2 for the fronts and bridge the other 2 for the sub. alternativly, you could get another 2 channel amp, depending on where you are going to mount them and how much room you want left. remember, amps are generally designed to get rid of the heat when they are sitting normally...so if you mount it upsidedown and its being put to its full potential, you might have an over heating problem and then bye bye amp!
hope this helps, hope i didnt sipn too much crap!
  • 3 weeks later...
thanks all for your replies :D
i've decided i don't want to spend money on another amp just yet...so here are my options:
a) Use the amp to run my splits, and run no sub for the moment
B) Use the amp to run my sub and run splits from the head unit
I'm leaning towards (a) because my splits were pretty expensive and are quite good quality so it would be a waste not running them off an amp.
what do you think?
Yup, subbies require more power to generate a decent volume.
Hence why most subbies are around 1000w and you will not find much above 300w for other speakers. Really for a sub, an amp is essential whereas for splits its not.
I hooked up my splits to the amp but it lacked bass... so then i hooked up the sub to the amp and ran the splits from the head unit. It sounds sweet :D
I might get a cheap 2 channel amp to run my splits though because the sound is so much clearer with an amp. Anyone know of any amps for sale?
Thanks for your help all
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
