well have u seen us in the same place at the same time
could be one and the same person *twilight zone music*
wish i could pedal a car as well as Denver, only got afew MC's under my belt.
and Shhhhhhhhhhhhh ur suppose to make en guess how old we are. even though it should say it under my name.
so far i've got a 22, 24, 23 and one cruel bugger said 30 at work today.
Thanks Miss Pie
Pie tah for noticing, ive been trying to keep it quiet, jason/uneekwan rang me this morning so i guess it had to come out some time..
As for the freaky twin thing, well i guess i better fess up, troy and i are really the logans on big brother atm, yes troys undies smell..
troy wish i could explain how i learnt to drive like that, im still waiting for the offers of drives from ferrari and prodrive when schuie and solberg retire.. heres hoping..
Kim *reow* look out big boy
and paul im suprised too, i figured id be dead by now..
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
