I have had mine for about a year now. It has always spiked about 1psi, then dropped back down. I was never worried as someone posted that was normal/ok. I actually got it on a dyno though, and that spike makes the fuel lean out heaps.
Also, to get 12psi on mine, the 'tap' is JUST gripping the thread. It is ridiculous how much thread it has. If I screw it in 1 turn, I hit 19psi.... have they fixed this in the new one?
Who on here has used these boost controllers on a dyno and watched boost/fuel ? Wondering if mine was stuffed from day 1... Should I buy another or go eletronic?
Cheers
Chris
Edited by eXc
  • Replies 1.8k
Posted Images
I've had a tuner tell me not to buy an ebc, keep the one i've got because there great
mine spikes a tiny bit about half a psi when it hits full boost and even though my car drops off power at about 5800rpm the boost stays at 14psi all the way through and past redline, afr's stay fine. Yours sounds weird, mine is about in the middle of the thread and is cranking 14psi, so maybe its shagged?
Hi guys,
I have a r34 sedan gt-t. I have no idea about boost controller as i've never installed one before, perviously owning a v8 :sleep:. And i was going to ask you a BIIGGG favour if someone could send me a few pics of how you did it and where its installed, and if you could give me a few pointers on how to install it so i dont get full boost like one member with a r34 was on this forum. If you have a step by step method with a few pics that would be great.
Anyways, i appericiate your time, and if you could help me it would be great
Hope to hear from you guys soon. Cheers!
Thanks guys :)
btw boost tap is turbotech :bomb_ie:
Edited by DRFT31
Hi guys,
I have a r34 sedan gt-t. I have no idea about boost controller as i've never installed one before, perviously owning a v8 :P. And i was going to ask you a BIIGGG favour if someone could send me a few pics of how you did it and where its installed, and if you could give me a few pointers on how to install it so i dont get full boost like one member with a r34 was on this forum. If you have a step by step method with a few pics that would be great.
Thanks guys :)
btw boost tap is turbotech :)
It's real easy, should only take a couple of minutes to fit. I will try and take some pics tommorrow of mine (also a R34 GTT 4 door) but basically you just plumb in the bottom of the T on the MBC to the wastegate actuator (so you unplug that from the solenoid). Then you pull apart the "Y" shaped hose adapter already in the car and you plumb the other bit of the T on the MBC onto the tube that feed the turbo presure back to the solenoid (bypassing the solenoid altogether). Then you just gotta block of the other thick host that goes back to the BOV plumback pipe (I used a bolt and a cable tie).
Then you just have to adjust it. This is the point you need to be careful, minute changes to the screw changes boost a lot, and its easy to go from 8psi to 15psi by mistake (i did this for a billionth of a second hehe).
I recieved my controller today :) and installed it but have been quite dissapointed with the results :P . Boost comes on quite slowly when you put your foot down from low revs. Also i can't seem to get it to go over 10 - 11psi even with the controller turned in clockwise till it cant go any further. i looked inside and its got the ball and spring n everything but doesn't seem like its woking properly.
I installed it where my old turbosmart bleeder was directly in between the ic piping and the wastgate actuator which used to create boost a lot faster but laged on gear changes and spiked a lil. Something must be wrong with the controller yeh? any idea's? BTW the srew bit is in line with the line coming off the ic piping, as in the screw is perpendicular to the line running to the wastegate- is this correct? Anyone had this issue before or simular?
Any help would be great
Thanks
Edited by R33silverS2
I recieved my controller today ;) and installed it but have been quite dissapointed with the results ;) . Boost comes on quite slowly when you put your foot down from low revs. Also i can't seem to get it to go over 10 - 11psi even with the controller turned in clockwise till it cant go any further. i looked inside and its got the ball and spring n everything but doesn't seem like its woking properly.
Thanks
From your description, it sounds like you have it hooked up correctly.
Try taking it apart (don't lose the ball or spring) and make sure the spring isn't catching on the thread inside. I remember a few others having this issue.
I will give it another go, when my car comes back from being serviced. Does anyone know what way the spring is supposed to go? is the cut part supposed to be against the bolt or against the ball??
Ok got my car back and first thing i did was take the turbotech off and pull it apart. I couldn't really tell if the spring was catching as i just tipped the controller upside down to get the ball and spring out. Anyways i turned the spring around so that the flat part was against the ball - it was the other way when i got it, and carefully made sure the spring wasn't getting caught and voila! works great now holds 10psi goes up to about 11 or so at times but my car has always had terrible boost creep.
When i first took it apart and re-assmebled it something must have gotten stuck cos it was on unlimited boost i think and got to 15psi by 3000rpm till i totally freaked out... :thumbsup: Anyways problem fixed either turning the spring around fixed it and the spring was stuck or something but works great now. :O
oh sorry, read ur post/s wrong. I thought you took it apart... got your problem... posted in here, then you took it apart again and fixed it. I thought you buggered it the first time you took it apart... i didn't realise that this was AFTER you had the problem.
oh well... all good :D does yours have a little hold drilled in the top?
oh well... all good >_< does yours have a little hold drilled in the top?
Oh i see, Yeh it was when i tried to fix it cos at first it wouldn't boost at all - as in it was turned all the way in and would just go to 6psi and slowly climb. so when i opened it up and put it back in it did the opposite! probably was gonna go to infinite boost cos it got to 15 before i though ohh sh#t. Anyways holds now, but one thing ive found though is there is quite a bit of lag on the gear changes. Anyone else experienced this? mine doesn't have the hole in the top, I'm assuming this is why?
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
