  • Replies 1.8k
Posted Images
they have steel wheels, otherwise standard :huh:
only GTR standard turbos that are steel exhaust wheels are, N1 or nismo turbos. the R32 R33 R34 are all ceramic exhaust wheels.. unless they are a N1 or A/M set. :D
i fitted one to the S14 today need a gauge for it.. so waiting till end of the week.
mark sent me mine in around 3 working days from payment.. quite quick.. :wacko:
maybe groper's referring to the fact that he either has one of the 'factory' steel wheel turbo's or he's had the ceramic ones replaced with steel wheels... possibly...
ok like the 100 other posts before. i purchased one of these boost controllers. i already have a gfb valve already set up on the car and was installed by the previous owner. could someone give me a quick run down of how to install the new boost controller in replace old the gbf, is it just a straight up swap.. disconnect the hoses from gfb then connect them to the turbo tech one?? or is there any change or extras i need to be concerned with. im installing it asap so any imediate help would be awesome!
thanks
jake
so anyone posting a DIY mod for retards or what ?
mine should get in soon so i can hit up 10psi. i dont know what it will look like or how it will work bt if its shithouse on a gear change i will want to change it.
Edited by gts-4 dreamer
Yeah man is that a question?
Look at the link in post 1449 on this page for a "DIY guide for Retards" ha ha
edit: grammer
Edited by KeyMakeR33
i run mine without the hole and have no boost problems whatsoever with it .
it spikes a bit early in the rev range but after that its quite good
That looks like quite a bit of a spike though 16.5psi down to 12.5, did stock boost on your car hold a flatter manifold pressure?? looks like it fluctuates quite a bit.
hey guys,
i just installed this boost controller in the other day.
it seems pretty good now that i have drilled the whole but 1 thing i dont
understand is that i wind the nut all the way up (lowering boost) yet my
boost guage shows .7bar to .75bar BUT if i was to wind it down (up the boost) my guage will show .8 .9 1 depending on how high i set it, so in other words i cant get it to stock boost.
Shouldnt it be showing .5 because the boost
is all the way down???
would this be because the controller isnt installed right or boost guage not reading right.
MODS:
cat back exhaust
pod
atmo BOV
(apexi boost guage)
any1 come across this before???
cheers
Edited by RB32
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
