we actually have our members cruise on this weekend...
If you were a member that would be the perfect thing to come along too.
If your cursing...
http://www.skylinesaustralia.com/forums/sh...ead.php?t=60590
join up and the next one is a few weks away
is any1 Cruiseing this friday or satday night if so tell us when n wear n iam coming  :headspin:
hey dude, nice looking R34... I've seen your car down @ chapz many times ;) there's a mccr cruise on tomorrow night.
When : Friday 13th of May
Meet : 7.30pm
Depart : 8:30.pm
Where : LONLEY PLANET - Dockside, Corner Maribyrnong St and Parker St, West Melbourne.
MELWAYS: 2SJ12 (see attached map)
Bring your UHF CD Radios if you own them – MCCR Channel = No14
hey dude, nice looking R34... I've seen your car down @ chapz many times :) there's a mccr cruise on tomorrow night.
ha yer i thk i seen ur black one many times a chaps and when i got my 1st yellow peace of stick paper named after a bird u drove pass,
and r31nismoid i just filling out my paper and sending 2moz "friday"so i be able 2 come soon!!;)
Damn I been invited to a party.. how long this cruise gonna go for?
Guys - I have no affiliation with mccr, anyone can go to that cruise as it's open for all. It is not an official SAU cruise, in fact most SAU members would prefer not to attend mccr events due to the number of bad drivers that commonly attend and ruin it for every one else. There is likely to be police showing up at some point so be warned.
I was just posting the info for anyone who may be interested.
the curs is going 2 go donw dandy road den FKN CHAPS i pray i dont get pulled over agian and after dat i dont know hope that helps hay gttr34 u frineds with speedskills the black r34 coz i thk i saw u last night with couple others donw chaps????
noble park maccas 8-30 satday night leaving at 9-30 me and some mates going 4 curise so any1 can come just look 4 my car:D
i was the guy in the black R33 that pulled up next to ya at Maccas... Nice car dude, looks awesome. and your old man is cool, can u pm me the details for wolf..
thanks
mike
shore no probs i send it 2 u,by pm when my mob charges up, the cursie was alright no cops but need more ppl mabye next time will be better
cool, thanks for that. glad the cruise went well and no cops. how come u didnt turn up for the cruise today ??
mike
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
