311 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 148
Hi people,
Go read SPEED magz issue 12...
there is a contest between 4 cars, GTT vs Supra vs RX7 vs S15....
SUPRA came LASTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT....
Sorry to see it.. lol
It might be fast in straight line but GTT will out run it on corners anydays...
BTW... for those who wants to know the resaults.. RX7 came first..
GTT is a good everyday car.. (i know i have one, use it everyday)
S15 ... is king of drift..
Supra... not much to say abt it... lol
r34 GT-T definetely... lighter, better looking, same amount of power standard :rofl: only downside is that it has a less amount of torque due to the supra having an extra 500cc n havin twin turboz instead of single
yep just took delivery of my GTT and have clocked close to 2000k's in 3 days! I can't stop driving it, its a brilliant machine with a great all round package, even in the tip-tronic. My old R33 doesn't hold a candle to the 34's stiffer ride, running gear, traction control etc. etc. etc. Not the quickest car in a straight line but in the corners it makes me smile ear to ear. Can't vouch for the RZ's performance although I dont think I'd swap this thing for anything but an R34 GTR :rofl:
Where can I find out more about issue 12 of SPEED magazine?? can anyone turn it into PDF? is it the latest issue?
Hi people,
Supra any day. A GTT isn't even in the same league imo.
Read some PRO's advice (SPEED) be4 u start to give stupid comments...
and what different league btw??
JDM vs JDM
FR vs FR
Tubro vs Turbo
both 14** kg vs 14** kg...
both 206kw stock????
WHAT different league???????????????? :headspin:
JDM vs JDM
FR vs FR
Tubro vs Turbo
im quite sure RZ's have 225kw stock
JDM vs JDM
FR vs FR
Tubro vs Turbo
Stupid comments? Let me clarify my post then.
By different league i meant that the Supra is a GTR competitor. Sure they're both JDM and FR platforms, but I wasn't saying that they are totally different cars.
The 343Nm of the GTT is quite a bit lower than the 451Nm of the Supra. That's almost 1/3 more torque. That's like comparing an RB20DET powered GTS-t and an RB26DETT powered R32 GTR.
BTW you really can't compare the power ratings as the Supra would have quite a bit more than 206kW.
EDIT: Changed the cars I was comparing
BTW I have read that Speed article, but it really is just an opinion piece. I can't see how they're "PRO's". Sure they've probably driven a lot of cars and are more qualified to judge the cars than me, but aren't they just fellow enthusiasts driving cars and then writing about them?
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
