  • 3 weeks later...
  • 1 month later...
Could you explain why it cannot be done if you have an immobilizer? what must be done different to get it to work?
I just got my Greddy turbo timer......but waz unsure where to get it installed as i have an immobliser (so cant DIY).......i know car toys can do it 4 $95 but dat seems pretti expensive..........do u guys know any1 who could do it 4 a better price.......
        Cheers
Will do it for $45 live in the hills. just out of interest what sort of Immobiliser is it and is it a basic t timer or one with Rpm and 0 - 400 time etc.
If youve got an Immob you have to wire the timer up so that the car still runs when armed but when timer cuts out can't be started.
care to explain how I can do it? as I recently had a alarm installed and now my basic turbo timer no longer works presumably due to the imobilizer?
I'm planning on hooking up a Greddy full auto turbo timer soon.
i think you would need to hook up a relay or two?
whe the turbo timer is running the relay would cut points of the imobiliser once the turbo timer cuts the engin the relay will connect the imobiliser points...
this might make it easyer for somone to find the imobiliser wires and knock off the car though....
If it works ill post up what i did if you like.
Adam.
Hi Adam,
That would be great, as I'd like to get my TT working again .. Its annoying that I have to drive like a sissy for a few k's to cool down the turbo now .. :P
Adam.
Its easy enough to put the tt in with an immobiliser you just have to hook it up to the ignition after the cut for the immob. this way the can can still run but only on tt hope this makes sense. Also if your alarm has a ignition sense you should wire it to accesories so that you can arm the system while the tt is in.
I was actually thinking that too, but thanks for advising ..
I will give it a go on the weekend.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
