In the future I'll be looking at getting a 180 of some sort. I know the SR20 get praises from everyone but is there major problems with a CA18DET? I have heard rumors that they tend to through the main bearing after about 100,000km and yet I know of people who have had their car since about 70,000 km and its now gone well past 100,000km without a problem. Can anyone confirm or disprove this? What about performance wise? I know the 0.2 of a litre would make a differnce but how much and what about modifying options are there as many as the SR? I do remember reading an article in Zoom about Dexter's CA18 180, it had a lot of work done to and fairly flew, so going by that they can't be that bad, are they?
https://www.sau.com.au/forums/topic/7368-ca18det-whats-the-go/
they're just getting on a bit mate, yeah the bearings will go, I think number 2 is that one which kicks it the most often (least oil)
the turbo can also be another worry since that'd be old too, so a split hose all the way to major shaft play etc can be seen (when you look at them and notice oil underneath it's not always the engine - could be the turbo oil drain pipe having a leak (check bov, if it has one, for large amounts of oil coming out, a little is fine; or else when you start it at the exhaust), checking the oil filler whilst engine is on, to see if it is bypassing the pistons (at least I think that's what its doing) - a large rev change isn't good haha
whats wrong with the vlt?? :P
personally I'd go for 2L out of the two
also the money you may have to put into the ca engine over the next 18 or so months to maintain/fix may be the same as getting a lower mileage sr in better nic
but as you say - some engines go a lot further than newer ones; it's all to do with how tough a life its had :P
turbo's don't generally have an easy one
i had a silvia b4 the gtr n it was a ca18det, i rekon they are a fantastic little engine. mine had a high flow turbo, front mount, remapped com.,ect. runnin 14psi it did 138kw at the wheels and a 13.75 quarter mile. It was nothing to sneeze at, and they rev so sweetly and sound way better than a sr, sr's to me sound horrible; so drouny but thats just personal taste. The ca's are pretty bullet proof if looked after??!!. The turbo is a weak link so are the coils if the motors got more than 100k on the clock. It is vital you change the oil every 5thou as the turbo return line on the ca is undersized and gets cloged with burnt or old oil which can in turn block oil from getting out of the turbo and boiling the oil!!! Dont think the main is a major fault with them it can happen to any car as much as another. They do tend to do head gaskets, especially no 1 if boosted with shit fuel, n let me tell you changin a head gasket on a ca is not fun( eccs makes it a bitch) With similar mods the ca to a sr will always be around 15rwkw down but the ca silvia especially in man form are about 25kgs lighter than the sr equiped cars so its always pretty close!! as with all s13's 180's always seem to of had a harder life, so id go and auto silvia turbo with low mile then change it to manual which is what i did with mine (easy as job to do the change took a day) If you get an auto you can be more certain it hasnt been some jap boys drift mobile or had its a.rse wrapped!! Ne way good luck theres heaps more i could go on about so if you have ne more q's let me know.
Originally posted by LoudBlueBMW
The CA18 is a technically more advanced engine than the SR20 just it's getting older. And the CA would have to be lighter as well.
Im with LoudBlueBMW
Dunno about the weight tho as SR is fully alloy while CA has an iron block, So the SR also Revs more.
the ca is a cast iron block, the sr is an alloy block and weighs heaps less, is newer, pulls more torque and power
basically it's technology vs tractor ahahah
I'm not sure about durability of the two, like the amount they can withstand, but is was tested and proven that the sr can hold 250rwkw without internal strengthening...
exhaust note is purely subjective: I prefer sr since it's a nice, lous throaty sound; the ca sounds more 'sportier' (that is, imho more like an rb note than an sr)
Originally posted by 2fardown
I have read a few websites comparing the SR vs CA.  They are both great engines but the CA gets the more votes in most debates.  Meggala is currently importing a 180 CA...send him a PM regarding the engines etc.  He would be more then happy to discuss.
I' think i'll have to do that.....
CA is a revvier engine than a sr
from my experience ca's bust head gaskets through age or over heating often caused by loosing coolant through a crack frail water line on the right rear side of the head/block. bucket and shim RB style and the short stoke allow it to rev and live
the sr is a torquier better responsive engine but has weakness at high rpm due to its rocker arm stud removing themselves. also they aquire bottom end knocks, not too sure why probably from using bad oil or slideways starvation
Ideal combo CA18 rev head and a 2L bottom end...... did somebody mention dexter.....
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
