rb20 and rb25 afm are same size and same calibration.
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
OK the rb20/25afms are a good upgrade for the gtr rb26 with a pfc as the afms will plug straight into existing harness and can be selected from a menu in the setting of the pfc ,the only thing is, it normally requires some customising of the pipe work to the turbos from the afms (the same as would be required for the z32) and the best advantage over nismo units is price and less restriction to flow (80mm over 62mm) PLUS i remend de-screening them as the mash covers about 33% of the cross sectional area of the afm and the turbulence would be significant (just make sure you run good filters).
PS. if you are aiming over 540rwhp i would go the Z32 as my rb20/25 were reading 5.03volts(5.13 is max out) at around the 529rwhp mark, my z32 now read in the low 4volt range for the same hp.
cheers
Aftermarket piping is beneficial however it isnt required so to speak. If you dont have the funds they do sqeeze into the factory rubber piping. I did this with mine!
Piping is expensive. The Greddy suction kit is $1,100 odd delivered from nengun!
I have removed the rear screen on my afms. Not the front as I've heard conflicting rumours.
How accurate are these figues?
Need to get a resonable guess to get me started as i am soon upgradeing my RB20 afm to z32 using the stock ecu.
rb20/25 afm's are the same . I have rb25 afm's on my GTR if you have custom pods then they will probably not bolt up to the 80mm afm's like I found with my blitz pods. I just bought two gts-t pod adapters and mounted new filters . The rubber turbo intake pipes just squeeze over the back of the 80mm afm's help to heat them up they slip on easier. Have a look in my gallery have a pic of the my engine bay with rb25 afm's .
in my opinion if your looking to replace the std afms it means you are looking over 400rwhp as i believe that about where the std afms start to run out of head room, and that be so you are starting to look at serious power levels.
So concider this while people go full on with big exhausts and plenums and coolers to etc etc why would you run a resistive intake where the air has to be drone in (not pumped etc)
so the choice of good filters and intake piping and large not resistive afms are very important as this is the first link in the chain
(as what air you are trying to pump through the rest of the system must pass through here first and must do so under no pressure only by the vacuvm of the turbo intake)
eg why put a ~2"x2(ID)grilled afm on the intake and a twin 3" exhaust or 4"intercooler
the grill takes up about 33% of the cross sectional area of the afm and serve no purpose but to add resistion to air flow(i believe the only reason the grills are there is to stop objects touch the afm elements).So if you run good filters and dont go putting tools or fingers into them the grill is redundant.
my 2c
I made a post a while ago about running the AFM inline as well as increasing the ID of the pipe the AFM is installed into to allow more power before maxing out etc.. I got no responce..
I will be trying this on my own setup though. The AFM probe is simply O-ringed into the pipe. I think if I run a single GTS-T 80mm AFM inside a 4" pipe, this will have the same flow as 2 x 3" pipes, saving a lot of space :(
e.g a 80mm GTS-T afm in a 4" pipe should in theory allow 453rwkw. I'm not sure how this would effect the resolution however. I was hoping an expert could shed some light..
Seems like a lot easier and cheaper way to do things if it works. I know of a few cars running AFM's inline on the pressure side of the piping. Normally after the Intercooler.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
