Found bendix fade a bit too much, yes the ultimates or premiums or whatever they call em now.
Really liked "Green Stuff" by EBC and hear that u cant go past race brakes RB26's which are well priced too. I think both of those pads are semi organic.
My personal favourite is Endless SS-S, low dust, great initial bite, progressive and rated to 500deg C, so not likely to fade on the street. Oh, and they wont chew the ass out of your rotors either. I have also found project Mu are pretty good, not quite the same intial bite as endless, but otherwise on a par. I have also tried bendix and greenstuff, didnt think alot of them (personally), better than stock though, but dusty and seemed to wear rotors like there is no tomorrow.
your brakes will perform ALOT better with good pads than if you upgrade and use normal pads, (I went from stock SR20 brakes with project Mu pads to stock R32 brakes, and the SR20/project Mu combo pissed on the stock R32 setup) Once I fitted endless pads it was a different story though. Good brake pads are an excellent upgrade.
I would recommend getting the best you can afford, what price your life? cheap insurance and alot more fun driving the car.
I don't think it's your Ultimates that fade. I've never experienced fade in my Skyline and that's all I've used so far. I've been to about 10 track days and as everyone around my area and on this site can attest, I drive my car hard.
there are more factors to whether or not a brake pad will fade than just the pads, tyres, driving style, how tight the track is etc.
Your pads are obviously ok for how you use them, but not in Boostzor's case. I have know other people that have had fade on ultimates (so they told me), even though I didnt get it.
Alot of variables.
Yeh if the rotors are bigder they are going to dissapate more heat, so if they are thin they fade faster. When i had them they were on a jza70 and the rotors were about half way done. After 3 hard brakes u could feel it fading.
As steve said though, EBC ab RB chew rotors good. Too bad the endless are so expensive.
I would recomend do it youself or get one of your friends to do it Erik.
Just got back from the place in Bayswater (no name)......whata bunch of cowboys.....
They frucked one of my wheel nuts and their reasoning was " who did your wheels before" and that is after they takend them off , put them back on, and took the car to do the alignment....
.....and then they had decency to tell me its ware and tare..........dick****fiths.........:cheers:
All that: for them to tellme there is nothing wrong with my car.......
Well I get to the breakes now. I ask them why is one of my brake pads bent inside after I replaced them ....... and the guy tells me we are specialists but I don't know!!!
Whata???
So after spending so much money on different barke specialists that know fruck all...
Wheel alignment specialists......same......fruck all.....
So much for pro help.....
I have decided from now on, even with not much time these days I am doing it myself.....
Read the forums guys, ask for the manual if you need one, I have one, so does Paul and few more other people. DIY!!!
Boostzor, endless may be a bit pricey, but stack up well against others when you consider the money you save in not having to replace your rotors so often - more rotor = better brakes :rofl:
Abo Bob, bigger rotors can make a difference, both in thickness and diameter, as can the design. Take for example the 'roo paw' (or whatever its bloody called) design of DBA rotors - they spent alot of time and effort trying to improve the cooling efficiency of the rotor. Then you have the material that the rotor is made of which also makes a difference.
If you have aftermarket/upgraded rotors, there could definately be a difference.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
